AT IT AGAIN: Paul and Mike Convert a Mid/Tall T1N Sprinter Cargo
1leglance
wow that is quick and impressive....great teaching thread for those of us who have trouble figuring out how to home build something like this.
mog
Kodiak Buckaroo
Yea ! ! another PaulJensen build...I now have a reason to get up every morning :wings:
I look forward to another thread chocked full of great ideas and beautiful work, a true inspiration (of course sometimes I think that inspiration is to just drive my truck north and have the master do the work).
Hopefully the troll(s) will not get fed in this tread.
PaulJensen
Custom Builder
#2.1
After surfing, back at the shop I re-installed the headliner...
(above) It's solidly in there...I'd feel fine with 50 to 75# up there...
(above) I forgot to mention two things...
1) The fabric is a cloth backed vinyl...The color fits in there way better than I was expecting when I walked into Joanne Fabrics...The fabric was $17.50 yd., and I got two yards...Luckily the check-out clerk gave me a 50% off coupon...Always nice to get 50% off...
2) The other thing is that before I glued the fabric to the wood, a round-over bit on a trim router was used to soften the exposed edges...
BTW: The surf was good, the wind and water cold...The wind became fierce so I went body surfing...
See you next week...
1leglance
I was digging the surf talk right up until you mention cold wind and cold water....then I bailed :) Just don't like the cold but very cool that you squeeze in some play time along with the hard work.
Thanks for posting all this.
_hein_
Looking forward to more creative work. Nice waves.
Has the work they were doing on the jetty been completed?
PaulJensen
Custom Builder
#3
With the front cabin headliner sorted out, the process moves rearward...Today the focus is building the driver side, upper wall cabinet...
(above) The starting point...
(above) This is what was up there...
(above) 3/4" birch ply, brackets, a few nails, no glue...
(above) My idea is something like this...The bottom edge will be rounded...To do that I'm quartering a piece of 4" PVC pipe and bonding it to 1/4" plywood...
(above) To cut the pipe a captive box was built...
(above) The pin nails will keep the pipe from moving when being cut...
(above) On the tablesaw...
(above) 4" diameter quarter rounds...
(above) Full size plan...
(above) To glue the components together, this jig was slapped together...
(above) To get the spacing right...
(above) Epoxy will be used to stick the stuff together...Epoxy does not stick to plastic packing tape, so a strip goes under all the joints...
(above) The PVC pipe is scuff sanded with 40 grit...
(above) 2" fiberglass tape, two layers per seam...
(above) Resin Research Epoxy is the only stuff I used...A generous amount is brushed on, then the glass is laid over...Another layer of glass is laid over, offset by 1/2"...
(above) The other face of the cabinet is in place and glassed...
(above) The screws you see will get removed tomorrow when the epoxy has cured overnight...
(above) To accelerate the cure a heat gun waving for about five minutes speeds up the process by an hour or more...
(above) The old case side was used as to make a new, more accurate pattern for all the new vertical ends and dividers...
(above) The level, masking taped on, helps the scribing process...
(above) I had about an hour long break when Zack and Laura came by to keep working on her board...
(above) Then it was back to pattern making...Close enough...Tomorrow I'll make the real ends and dividers as well as the curb side case...
Photomike
White Turtle Adventures & Photography
Long cold winters nights, need more to read :)
WOW that was fast I posted this and more was there, I like that!
njtacoma
I occasionally scoff when I hear stories of people that have lost control of their lives due to the death grip of addiction, and yet here I am twitching and irritable waiting for the next hit, I mean installment, in a Jensen build.
I enjoy watching someone that knows what they are doing.
rumpityz28
