i need to get my own camera enough of this sharing crap!
so the reason for posting the jana links is because i am considering running a high pinion dana 44 with dana 50 innards, (jana 54) in the front with 8lug outers and chrome moly axles, in the rear a high pinion 60 with dana 70 innards, (jana76) and axles. pretty neat tech in that thread. seems reasonably priced too.
this would give me good ground clearance, and strong reliable axles. granted i would be sacrificing width but it would also add stability and in colorado the full width axles don't seem to be a red flag for getting around.
warning long drawn out story ahead
so with that explained. i have been busy the last couple of nights, with this,
http://www.expeditionportal.com/forum/threads/64710-ever-get-that-feeling
(for those that don't like to clicky, short version wifes car went bleh in denver while visiting her sister, she's pulling her hair out i am pounding my head against the wall)
, and try to figure out how i am going to deal with the situation.
so it was determined i need to go down to denver to get her when i go on days off. so after i got off my 12 hour shift i started getting the f350 ready. the 35's i have on it are dry rotted a bit so i put the old/new 235/85/r16's back on. well let me rephrase that first i did the rear tires and adjusted the rear brakes so the parking brake would work again, looks like i need new shoes as the left pad is cracked and the drum is chipped, insert head **********. got that done. the other two 235's i had mounted on the front of the suburban so i could move it. so that meant taking the 35's off the f350 and the 235's off the sub. ok f350 first, done, lets tackle the sub. the sub had a bunch of weeds around it and 5 or 6 hornets floating around the front end. great so i grabbed the hornet spray and killed two nests that they had built in the pass door and ran out of spray. still loitering in my work area. dangit. screw it bee stings aren't that bad. so i crouch down to get the jack under the axle and look for more hornet nests, in the process leaning my forearm on a pissed off hornet. mother of willy nelson that hurt! drew blood and everything! time to take a breather.
so i will work on the exhaust on the f350 instead. it has a 4" exhaust with muffler that comes out behind the rear axle. i wanted to have it come out in front of the rear axle, so i could eventually put a bigger tank behind the rear axle. never liked the muffler any way so out it comes, but not with out venting my frustrations on it with a two pound sledge. done. a few creative cuts with the sawzall and i put it back together. lools kinda hokey but it works. time to go back to the tire swap.
i think by this time the bees where asleep or had moved on whatever, still feeling a little twitchy. got the first tires switched around. stepped back to look at my work. insert head ********** here. the wheels i have are directional and i had managed to put the wheel on the wrong side. it was getting late, i was frustrated so i called it a night. i'll fix it tomorrow.
woke up at 500a this morning and the explorer wouldn't start, no clicky nothing. that left the f350. that still needed one more 235, doh. since it was early i got out the 1/2 extended handle ratchet and the 7/8ths socket and went to work after i called in. one hour later i was on the road. the directional wheels looked like a blind man put them on, but i had made it to work.
so the lesson learned was; its the little crappy things that make the good times that much sweeter.
