RJ Howell
I'm here to learn from you all on even where to start...
I have a 2004 Ford F150 4x4 that is stock as can be and has taken on the good old Nor'east rust.
As the first step I had my mechanic (that has worked on it for years) give me a once over on the mechanicals, basically "Worth Savin'?"
Second step has been dealing with the rust. Now that the frame and body are solid again, it's time to move to the next step.
Intent is to build up a overland camper on the back (bed removed and up from frame) so I think suspension can be next. Beefing it up a bit and lifting an inch or so (to allow a taller tire).
Has anyone here actually made up a primer for the process (steps) in doing a build?
