Went out to find a new boulder field this weekend, took a wrong turn... had some fun driving around. Was good, settled the springs a bit and it feels good. So far things that have been great:
1. Duratracs - Was a peculiar weekend +10 Celcius (50 ish F?) on saturday and Sunday was a blizzard, and -10. Saturday, muddy (almost axel deep), wet slick trails. Studded, and self cleaning properties of these tires were amazing for what I'm used to, (general Grabber AT2's). Not very noisy on dry road surfaces at hwy speeds, and track well for a wider tire. Sunday, drive to banff from Calgary (140 km) in a decent snow storm to take my wife to a medical conference early AM. Vehicle felt very stable and traffic was much slower than the limit, about 30- 40 km slower. I kept pace happily, and with confidence in 2wd.
2. Suspension - Yep. Good. Stiff, but not much weight in the jeep yet, except for all the added hardware.
2. IPF lights - bright... nough said
3. Air Compressor - Slick and quick.
4. Diff Breather location - Will have to post a pic but I chose not to use the 'behind the tail light' spot for the rear, and ran it under the hood along with the front breather. Couldn't mount it along the firewall with all the other kit I got stuffed under the bonnet so it sits near the air compressor above the driver side fender. Secure mounting and it's way less dusty here than the typical rear spot. Not even sure if this matters, but it's a clean install.
5. Spod: Easy as pie, slick et al. However.... Mounting bracket is predominately on one side of the switch housing in the cab so it's not supported very well on the right side. Doesn't seem to matter though, its very light weight, and doesn't rattle. Just can't pull down on the unit on the right side or it will move substantially, 1/2 inch maybe.
The not so good:
1. Wider tires: After 140 km drive to Banff in typical snowy Alberta conditions my jeep was white and frozen door handles. I Was however, coming from pizza cutters, the wide tires had good traction and were very predictable. Any recommendations for front mud/slush guards? Mopar? Are there any others out there that are a bit wider maybe, that would help keep the side of this thing a bit less mucky?
Couple of before after pics:
Avoiding the deep water:
