cico7 XK Build
cico7
I used towing 4pin plugs for lights so I could just unplug it and take my roof basket off. I like that plug you got better but I need more connections then two. Do you have a link? Do they come with more connection?
Anderson Power Anderson Connectors
Anderson 30amp Amazon
Anderson on EbayEbay
I just found trolling motor disconnect which is like the trailer plug except it is 10g wire instead of 14 or 16...
Trolling Motor Quick Connect Harness - Rig Rite
Part # 400
10 gauge heavy duty connectors. For wiring a trolling motor where a plug and socket can't be used, (on small boats and canoes.) Header carded.
This image takes you to Walmart.....
Make sure you get both ends!
cico7
I ordered a 8.25" HEAVY DUTY Differential Cover for 10 Bolt
on ebay item: 270877370529
This is built by Swt Offroading near Bowling Green Ohio.
I was prompted to post this because of the number of posts I
have seen recently on diff. damages.
iStan814
