Nitromethane43
If you are looking for ready made "drywall compound" then fairing compound is the closest you can get, just mix the two parts and it spreads like bondo
http://www.jamestowndistributors.com/mobileportal/show_product.do?pid=97775
If you already have epoxy or resin then you could make your own by adding in fillers to your desired consistency. I am am too sure what your contours look like, but you can make the surface fairly smooth by applying resin or a loose mix over the surface and shape some cellophane over the surface removing all air bubbles in the process, once dried you can peel it back to a glossy finish.
Another thing is to use peel ply or the cellophane when laminating so the resin surfaces and the weave is pressed down to have a flatter finish without much sanding.
