Looks great! plenty of room and I dig the serving tray for the propane tank..............I like how you think!
What are the plans for outside? Paint, a wrap, graphics or keep it low key?
Very cool out of the box "No Pun intended" ideas!
Taco del.... the shocks work very good in that position. before I had them on the trailer would bounce around pretty good. The spring shackles are at the back of the springs so when they are compressed the spring assembly goes backwards a bit thus compressing the shock. They are rancho 9000 on setting number 6.
Gregster... It is still the stock axle (3500 lb) I am currently just running adapters, I will eventually swap out the axle so it can have brakes though.
...Gregster... It is still the stock axle (3500 lb) I am currently just running adapters, I will eventually swap out the axle so it can have brakes though.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
