Creating a Cross Canada Overland Route
Day Two Ontario
This report is from back in the spring of 2010. Day one left off in a town called Ompah, Ontario. This report is from a trip to explore and route day two of this province.
Met up with Juames and Dan mid June to push the route further west then north up to a small city called North Bay. This section of the route had been examined in detail, many many times. Originally we were to route through a town called Huntsville. That portion of the route had to be re routed due to the G8 Summit taking place in that town We all knew about the G8 but somehow never put two and two together until 2 days before departure. I was a bit dissapointed as I was lookintg forward to some of the trails north of Huntsville that run along the edge of Algonquin Nation Park.
As usual we met up at a Tim's for coffee and to look over the maps again.
Bikes loaded up for a few days
This will become a reoccuring theme, blasting some slab to catch up to the route.
A bit of gravel thrown in for fun on the way west
Look out for these guys
Some fun twisties
We last left the route ending in the town of Ompah, Ontario. Ompah has a couple of nice campgrounds, a gas station/general store and a few other small businesses. This is a recommended gas stop on the route and would make a likely place to spend a night.
Happy to be back on the route and making progress again
The route takes some slab for about 20 minutes before getting back into some back roads.
These backroads lead onto a long hydro line
44.739296,-77.320662
The hydro line seemed to be in good shape. I had done a trip a couple of weeks back where we rode a long hydro line/back road section that I was sure was this section. It only took about a few minutes to realize that this hydro line wasn't the one I thought we'd be riding. A quick look at the map again just to double check we were in the right place that we'd highlighted for the day's route. Yep this is the one we had pencilled in, ah well it looks long (50+ km's) and so far it seems to be in good shape ..........
A nice gravel base, well travelled, looking good
Things started to get wet. Water crossing after water crossing. The good news was that they all seemed to be gravel based and the water level's never got over the front tire.
Some of the water crossing got real dark and murky. A red tint to the water from some mineral in the ground I suppose. Looks cool but a bit unnerving when you don't know how deep they were. We did due dilegence and pre walked a few of the more suspect one's just to be on the safe side.
Juames takes one for the team Heck once your wet your wet, you can't get more wet
Dan getting a big kick out Juames getting wet......his turn will come
Ontario Day Two Continued
And on we go.
These are the one's that make you nervous. Weeds on the side, trail going off into the bush and turning a corner so you can't see how far the water keeps going.
At this point I starting to think that this is working out pretty damn well. Lot's of water, but this should be close to high water level's and we haven't come across anything that doesn't have a gravel bottom or is too deep.
The water crossing with the large rocks in them require a slow and steady speed. Just enough so you bounce up over the rocks but not soo much that you'll endo. Going to slow will lead to a tip over and you come to a stop and loose momentum. But there are so many of them that we are all in a groove and doing fine.
My turn to walk one You just have to know that at some point your luck will run out. Better safe than sorry.
I don't have a pic but I think this is the one Dan decided to cool off in after a tip over ? Never a camera around when you need one eh Dan
Now don't get me wrong, this trail wasn't just water crossings. There were also some very fun dry sections.
Just as things were going well, we check the gps and maps. Looks like another 6 km's until we pop out onto a road again. yehaa almost there ! Minutes later we come over a rise and are greeted by this view.
A quick conversation is had..... where is the trail? That can't be it ...that long dark watet section....it's got to go out and around in the bush and we just can't see it..... well let's head down and find out ....
If it wasn't for the unknown "where does the trail go now feeling" this would have been a nice vista. I love when the trail your riding dissappears from your line of sight in the horizon.
Well down we go. Loose rocks, steep and I can't help but notice that it doesn't seem like many vechicles came down here. Grass growing out of the middle of the track .... hmmm .......
Get to the bottom and are greeted by this view
A quick look around and I can see a fire pit, old spark plugs, old rubber belts from a truck and other signs that some one spent the night here working on a vechicle. ********, damn, arg. Juames goes and checks the inevitable, slick mud bottom and about 20 feet in he sinks to past his knee's
Damn we were so close to the end of this trail. Did we go the wrong way somewhere ? A quick check of the map shows that we are on the right track.
Why is that everytime I get stuck it's at the hottest point in the day, humidity jumps, and the bugs come out for a feeding frenzy. I guess being down low here out of the wind and right besdie a swamp explains it, but still ..........
Ah crap we're going to have to ride back up that steep hill covered in loose rocks I don't see this working out too well for us.
Got to the top of the hill looked back and saw this
What you can't see is Dan in almost the same position further down the hill. Why pictures make hills look lame is beyond me but this one was fairly steep and the rocks were very loose. A bit of pushing and grunting and we all got back under way to retrace our path.
And yes I put the camera down and helped out
Riding through all the water was much easier when you have confidence of what's under it.
After some debating over the maps we found another trail that lead off the hydro line. This enabled us to keep apart of the hydro line in the route
Check out the BIG bug in the above photo :ylsmoke:
Part way along the side trail (which turned out to be fun and fast) I had a quick chat with a local guy who has a hunt cabin in the area and know's the lay of land fairly well. I mentioned we had come from the hydro line and he laughed and said "you didn't make it did you, that swamp gets deep". Looks like we made a good call on turning around. he did however mention that there is a go around but it involves riding up and over and through a large boulder garden. He laughed when I asked if it was doable on our bikes. "I did see someone do it on a bike but it was a small little dirt bike". Enough said for us, we're here to make a route for bikes packed with gear, not to create the world's hardest enduro course.
After a few miles of the new trail we came across this and I thought ah come on
It appears as if the bridge is just getting some work done to it, yehaa...finally the route is progressing
Came across this little stream which was great to cool off in.
Rolled into the small town of Flinton Ontario. Not much here but a small general type store with a sweet lady who makes soup and sandwichs. Great food, I'd highly recommend stopping in when you come through here. real salt of the earth type of folks. Heck she even felt bad about overcooking my grilled cheese and apologized and offered to make me a another one at no charge. This is why I enjoy travelling through these out of the way places, the people are golden.
After lunch we broke out the maps and figured out how to get back on track. It looked like there were some gravel roads heading back to where we wanted to be. Sadly it'll involve a few short paved sections but it's the best we could come up with. Sometimes a bit of slab just to get the wind running through your jacket can be a good thing
Off we go....we make it about another 30 km's down a gravel road and stop at a stop sign. I take off and ride another 20 km's and wait at the next intersection...where is everyone? Wait an appropriate amount of time then start retracing back to where I last saw them. You can't help but think one of three things has happened.
One: Someone had an accident
Two: Someone had a mechanical
Three: I went the wrong way and now the epic how do we find each other again begins
Well turns out it was option two. Juames bike has had an electrical glitch of some sort and has no power. When I get back to them his bike is stripped of gear, seat, fairing, etc Much poking and prodding and trying this and trying that and we came up with either the battery is toast (he just put a new one in a month or so earlier or he has a short that draining the electrical system). Lucky for us it was the KLR and not one of the KTM's. A KLR doesnt require a battery to run. The ignition runs off the stator A few attempts to get it bump started and away we go...only to see it die again another 100 metres down the road. The petcock had been turned off when we were about to remove the tank
A group decision was made, do we camp for the night then find someone with an voltage reader in the morning or do we call it quits and head home. Well we decided to head home. Hard call indeed. The tipping of the scales was that two of us are married and getting a weekend off to go biking isn't something we get to do every week, so it was decided that it would be better to limp home, get the problem sorted out and return in two weeks to finish making this section of the route. (I know your thinking your married and you get to do this much biking? Well Mrs. Deadly either doesn't like me or she understands me and puts up with me taking off many times a year for bike trips....... I think....I hope...it the latter )
A stop for dinner on the way home and a few coldies to drown our sorrows in.
There's something about having a cold one after riding with your buddies and recalling the moments of the day that simply puts a smile on your face.
After a retarded session of trying to bump Juames bike and subsequently sweating out the bevies we headed home. Juames must have been cutting it close with his little to no headlight due to no battery before it got dark.
Well another chunk of the route got completed, we had a good time and rode some fun terrain :sombrero:
NOTE: after some input from local's to that area it would seem as if the go around we didn't attempt is "doable" and the rest of the hydro line is fine as well. The hydro line is known locally as Lingham Lake Hydroline as it popular with the Jeep/Rover clubs in the area. We will zip out there this fall or next spring and give it a whirl just to see for ourselves. This may become one of the technical sections on the route with the Main Route following the route we followed on that report.
Thanks to those who emailed and pm'd me in regards to this :smiley_drive:
Ontario Day Two (Cont'd), Day Three and Day Four
Plans were put in place to pick up the route where last left off.
Ordered some parts for the bike on Monday, supposed to be in by Wednesday :( spent three hours in the shop yesterday until closing waiting for the UPS guy to show and he didn't. The ktm order (others impatiently waiing as well including the shops mechanics) spent three days being loaded onto a truck then redelivered to the wharehouse each night..******.
Flanny to the rescue ! He let me come to his place and "borrow" a much needed rad fan. THANKS Flanny :). Ps....any ktm 950 fanatics are going to be impressed when they see his next "Flannymobile" , a true work of art.
Bike is packed and sounding mean again :). Food, smokes, cheap Indian whiskey are all on board, ready to ride....not a cloud in the sky :). I even have an hour to spare, time for a quick siesta maybe
Too bad you can't come Dan, I don't think we will be seeing much dust....rained almost 30 mm (3 inches?) yesterday and everyday before that for a week.......there's going to be mud and water crossings, not dust unfortunately.
Vroom vroom, talk to ya next week.
Packed up the bike and headed out, sky was sunny and the forecast was looking good
Met Chris and Jimmy at Timmies in Perth, Ontario. Caught up and went over the day's plan. Everybody seemed in good spirits. I hadn't seen Chris since we parted ways in Newfoundland a month ago. His GS was showing some impressive battle wounds from his high speed endo on the Trans Lab. Jimmy as usual had the maps out and the route highlighted and his gps loaded up with the intended route
Hit the road to catch up to where we last left the route. This was also the spot where Frank would be meeting us. I hadn't met Frank before, I believe he read this thread, got in touch with me and voila...he's coming along. He self admitted his skills may not be what some others are. He rides a Harley ultra glide and just recently picked up a 990 adv and took a 2 day off road course, went and rode the Trans Lab this summer and then came and joined us for a few days of the TCAT ......
After meeting Frank we hit the road. The route begins with some asphalt twisties and some gravel roads.
The route then gets on an old rail line and heads north to the town of Bancroft. For the most part the rail trail is fast and smooth, a few sandy sections but nothing to really be concerned about. 80- 100 km's in ;length if memory serves, so a couple of hours depending on your speed. Some nice scenery, blah blah blah I really enjoyed this trail, nothing demanding just a stand on the pegs and enjoy the ride.
NOTE: The main route will take a gravel road (it's a good one) that paralell's this trail. Due to legality reasons I don't believe trucks are allowed (still looking into this, some swear it is, some say it isn't.
Entering the town of Bancroft. I really like the fact that some towns around this area really embrace bikes/quads/sleds as a form of tourism. This particular trail goes right into the middle of town. You can see the trail on the right side of the road, I wish every place on earth had trails like these
A quick scoot down mainstreet for some gas and beer. Yes in this area of Canada you can only buy beer in one place, The Beer Store. It's government controlled and more times than not it's not open on Sundays and closes at 6 pm on Saturday nights, plan accordingly
We slabbed for a dozen miles down to a provincial campground called Silent Lake Campground. Like all government run campgrounds, it's clean and whatnot. During peak season the gal at the front informs me a reservation is a must do.
Yep, they also rent yurts by the night. 90 bucks, sleep six. Not bad if it's raining and you don't feel like setting up the tent. Don't quote me on this but I think the gal said they have about 70 of them and plan to build more.
Setup camp for the night, got a fire going. Drank way too much cheap Inidan whiskey, just kind of happened, all of a sudden I realized I was slurring, ah well, it was a fun night shooting the ****, bench racing and whatnot.
The check in office
Ate a god aweful dinner. Never again do I eat boil in the bag freeze dried crap. I had a few bags left over from previous trips and as I was on a budget I decided to bring it along. To those who actually enjoy this crap.....:eek:
Stephen joined us at some point in the evening, he couldnt get the Friday afternoon off work. He rode the "route" from Bancroft to the campground........I'll let him tell his tale
TCAT Ontario Day Two, Three, and Four
NOTE: This next post is written by Stephen and reflects his take on the day
Well, Friday and me being the only person who couldn’t get the day off work I ended up getting a late start to things. I work in Arnprior so I rode my bike so I could leave right away and make my way to Bancroft.
Taking the nice scenic back roads through Calabogie I came across some wild dinners.. err. I mean wild Turkeys and some beautiful lakes where I just HAD to stop and take some ‘glam’ shots of my bike...
Later I rolled through the beautiful town of Bancroft and topped up my fuel for the next day’s ride. After that I thought I’d take some “back trails” to the campground. Well that was a mistake! I got about 2km down the trail and came to a short little water crossing with a culvert near the far end. Little did I know that it got super deep just as you got to the culvert. The next thing I know my front wheel is 3 feet in the air then my back tire hits the culvert and I slam down on my skid plate. I start to tip over but I save it before all my gear gets dunked in the water breaking off my right side mirror in the process. Now my bike is beached on the skid plate with the back tire floating in 2 feet of water. I'm alone, fully loaded, no one knows where I am and I'm about 3Km down this trail. Not good.
After much rocking and huge roost of water I finally get enough traction to get up the other side. At this point it’s getting late and my GPS says I’m less than 500 meters from the campground. Only a few more hills and I’m there! I hop back on and come to a gnarly steep climb. I gear down and gun it, dodging rock and sliding in the mud with nary a foot dab to get me to the top and that’s when I see the mud hole. ARG!!!! This thing was big, deep, and cris-crossed with 4-wheeler tracks. It was that thick mud that sticks to everything. The sun was almost down and I was tired so I said “Screw this” and turned around.
The culvert water crossing was easier in reverse and I made my way back out to the main road where I eventually found the proper entrance for the campground and met up with the rest of the guys who were enjoying beers around the campfire.
Yes, that's a marsh-mellow.
I busted out my brand new Henessy Hammock and set it up for the first time (I did do a test setup at home but I’ve never slept over night in it). Everything went up well in the dark and joined the team for beers around the fire.
I had a little more adventure than I had hoped for on the way in but I had survived. Later on I heard that the other guys were planning on taking that route but they were too tired from the earlier riding and were glad that I “took one for the team” and scouted it out for them. Little did I know that this wasn’t the last one I would “take for the team” before the weekend was out…
NOTE : Franks take on the day
I got back from the TLH at the end of August so when I heard about this ride, I signed up thinking it would be a nice follow up to the TLH. Just a small ride - 3 days, no big deal. So I headed out from Kitchener at 9:30 intending to make it to Tweed, about 10km south of the meeting point by 1:00. The RDV was at 2:30 but I had to cross Toronto on a Friday so a contingency was in order.
Toronto traffic was flowing so I got to Tweed by 1:00, filled up, bought a lighter - didn't think showing at a campground without a lighter would impress my travel mates. That would be almost as bad a planning to eat camp food all weekend and not bring any utensils.
I met up with the guys and we left at 2:30 sharp. I was a little apprehensive because these guys were on a mission and I didn't want to slow them down too much. They assured me they were not on a clock. We drove to the Hasting Heritage Trail and I was starting to feel pretty good. The 990 just loved that kind of riding. The ride to Bancroft was only about 75km but it gave me the opportunity to get my sea legs - or so I thought.
It was a beautiful day and setting up camp by 5:30 was really nice. A few beers, tales of adventures past and future, and everyone turned in. I was feeling pretty good about my decision to tag along. I didn't take any pics on this ride so I'll be relying on the other mates to provide the colour of the ride.
NOTE: Chirs's take on the day
Ted's covered most of the first day but I thought I'd throw in a couple of pix-
Typical section of the old rail bed.. firm gravel, gentle curves and hills, excellent scenery, a real pleasure to ride! Hardly any soft sand or endless sandy whoops, barely any water splashes, and no loose boulder strewn climbs. A nice way to ease into the weekend.
Frank and Ted talking KTM stuff. Jimmy the Map Man figuring out the next section.
Ted has not used the tent since the Trans-Lab trip and completely forgets how to assemble it. Not to mention that the elastic cord inside the poles is broken so he has to put together a dozen small sections, carefully thread it through the sleeve just right otherwise it all falls apart. Plus some parts are missing. Or broken. Something about gear falling off his KTM at high speed in the middle of Labrador.
Happily we stopped to camp at around 5pm and had a few hours of daylight to get set up, drink some beers, swap stories and get the tent up. Jimmy kept managing to walk into the guy wires. Bets were placed on whether Ted's tent would still be up in the morning
Frank, Jimmy and Ted discuss strategies for tent assembly..
TCAT Ontario Day Three
The plan for today was to ride from Bancroft to Kinmount for lunch then continure on heading north through Haliburton and end of in Hunstville for the night.
The morning's agenda had some gravel roads and one double track road called North pencil Lake Road. I'd ridden this "road" early in the year and remember thinking that it would be great to include on the route. At the time I was chasing a group of primarily smaller bikes and we were travelling with no gear. I recall thinking it would be "doable" albeit a bit of a challenge with loaded bikes
The night before I let the guys know about the terrain. I didn't recall any one feature that stood out as being terribly challenging, but rather alot of small features (rocks, water crossing, etc). There was one water crossing that was more than likely going to have to be skipped but there is a bypass atv track up and around it. I was hoping I had over talked it and it would end up being much easier than I had warned them about, usually riding a bike over tough terrain is easier if you havent psyched yourself out, but I didn't want to end up in a situation where everyone looks at you with hatred in their eyes thinking "what an ************ for bringing us here". Better that everyone knew what they would be up against.
So we packed up early in the morning after brewing some beans and having a bite to eat. Seriously, people eat that freeze dried crap and enjoy it? I had an egg/ham and other unidentifiable ingredients. omlet. The eggs were brutal but doable, the ham on the other hand just freaked me out. I forced down about a third of it just to get something into the belly as I had a feeling the day would present a few challenges.
The pace was slow as I had to stop at every intersection to write down info for the roadbook. About 20 kilometers of pavement before we got on a fun twisty gravel road. The roads were wet with puddles....hmmm....last time I road this road it was very dry...a sense of things to come was creeping into my mind.
Turning off the gravel road onto Pencil Lake Rd
Looking up the where we were headed. Wet sand and puddle's......they must have recieved some rain lately .......
Like I was saying, most of the road looks like this, or at least some of it does Nothing crazy but enough washouts, rocks and whatnot to keep you on your toes.
Then the "puddle's" got a bit bigger
Hmmm....I don't recall this many water crossings. The water had a weird algae on it that prevents you from seeing the bottom. Given the nature of the terrain I knew that there were some big rocks in some of them, couldn't help getting that feeling that " it's just a matter of time before I hit one and take a swim". How many of these were in a row? A dozen or so maybe.
Chris becomes the first to get wet
Not long after we got to the "big one". I was kind of hoping we could just ride threw it and not have to mess around with the bypass. Pulled up and we were greeted with this
TCAT Ontario Day Three Cont'd
You can see on the right side of the photo above a big rock, the bypass climbs up and over it. Everyone had a look and a poke to see how deep it was. doable? Maybe but with a loaded bike and on a multiday trip I really wasn't interested in watering out my bike. Go around it would be :ylsmoke:
I don't want to talk up this go around too much. On a small bike it's not a big deal. On a big bike with the proper amount of clutch it's not a big deal. On a mx bike it wouldn't even be worth talking about. On a big bike with gear and varying degrees of offroad experience....it's a challenge for sure. We all decided that we should walk it first and see what we would be up against........
The trail climbs a hill that is a bit steep in a section or two. It's atv width so it was obvious the panniers would have to come off the bike bikes as width would be an issue. Keep up the momentum and it would be no big deal. A few ill placed tree roots could be dodged and voila, you would be up on top.
A couple of us rode up with no issues and waited near the top to see how the others would make out.
Chris coming up on his big gs Almost made it before getting hung up on a root.
A little help from the lads and he was on his way.
I'm not sure why pictures sometimes make hills look mellow. This one sort of gives an indication of the angle this short section is.
Stephen heading up.
Chris doing shuttle duty with his panniers.
Once you get up on top there is a funky little section of rock, maybe 200 feet long. Trials riding when it comes to the big bikes
Frank looking proud
Then down a couple of switchbacks on the other side before regaining the trail.
One more tip over for Frank...didn't see it happen...exhaustion ?
The crack you don't hear is Stephen's pannier hitting this tree. He also lost his lock buckle on a tree on the way up. The other two lads with apnniers took them off, I think I would recommend taking them off
The rest of the "road" was excellent. Lot's of big "drive on" rock sections, some ledges, lot's more water crossing. 1st and 2nd gear type riding.
A dozen or more of these, some you go up, some you go down. Fun technical type stuff.
Riding first has it's disadvantages. We walked and poked alot of the water crossings. One of them looked innocent enough. Slow in first gear then I suddenly feel the front end drop. Quick with the kill switch Look back and wave the lads up to come give me a hand. Chris checked the depth in front of me and looked like it didn't get much deeper and was only deep for another 10 feet or so. atv stuck and dug a trench maybe? This is the only photo I have of it (I believe someone else got a few good ones). You'll notice my engine, foot peg, etc are below water line
More water, more rocks, more fun
Finding the shallow line
Eventually things dried up and the track became fun and fast again. At one point we came a cross a bridge out and a small water crossing to the side of it. A couple of lads on vstroms were there having a look. They had a video camera going as we rode by. One of the lads said they stopped and chatted with them and they said they were inmates at the asylum (advrider.com).....?
After finishing this "road", going from memory here but it's about 25 kilometres long and took us about 2 hours I think, we rode some very fun gravel twisties to the town of Kinmount for lunch. Real rollercoaster roads. A few hills with steep drop off's guarantee you will get some airtime Even the big GS left the ground. Have fun (Salmon Lake Road ), if I had my way we would have spent hours riding back and forth on that one road, but we had other promising roads/trails to get to. I'm not a wheelie guy but my front tire certainly didn't get the same mileage as my rear
NOTE: Franks view on the morning
Let the noob chime in here... Ted did sow the seed of awareness the night before. But as he described each challenge of Pencil Lake Road he always ended with "...but it's doable". I came to understand that to this crowd all trails fell in the binary classification of being either "doable" or "not doable". The obvious qualifier "by whom" was always conveniently omitted. So when we got to this crossing, and it was deemed "not doable" I had to see for myself as I had already seen the bypass. I had heard the "doable" pronouncement on the bypass and was desperately trying to determine that they had jumped the gun on the "not doable" verdict of the crossing. While I was still hoping against hope I heard the sound of Ted's 950 eating up the trail.
"I guess we're going around".
What was "couple of switchbacks on the other side before regaining the trail" for Ted, Chris, Steve, and Jim was some of the trickiest riding I'd done on the 990 to that point and I kept thinking, "holy **** I can't believe I'm doing that, holy **** I can't believe I'm doing that, holy **** I can't believe I'm doing that." Then as I came to the last 5 feet of the trail, nothing too different from what I'd just done, a sharp turn to the right I looked ahead and thought, "Holy **** I can't believe I just did that", looked up, hit a rock, and went over. So "loss of focus" caused that particular one.
Fortunately Jim was there to help pick up the bike...again.
NOTE: Jimmies take on the morning
I'm pretty much a noob rider myself. Had never ride dirt before last year, and very little at all before that...so I found myself echoing Franks words a few times as I was riding up the 'go around.'
I think Frank was seriously contemplating riding the water crossing... after closer inspection it was deemed 'not doable' to cross without a boat. The water was above knee deep in some spots...with a very sketchy bottom of brown goo that was most likely just as deep...
After all was said and done...we all made it up and around. And I must say the Pencil Lake road is a MUST ride! If you haven't ridden it...do it!!!
tbnd88
