SimplyAnAdventure
First off please read this entire question before just saying "NO".
I have a 2023 F350 Tremor with a 7.3L Gas Engine. This truck was ordered specifically for a Supertramp Camper that should weigh between 1200-1300lbs dry. Truck is new with 300 miles on it and I'm thinking about taking off the factory tires and selling them while they are still worth a decent amount. All the literature I read about the 2023 Tremors is they fit 37's with ZERO modifications.
Question, is it reasonable to buy a set of Nitto Ridge Gaplers in 37x11.50 R18 that are D rated, or should I buy the 37x12.50 R18 that are E rated? I would definitely prefer the more narrow tire (on my Tacoma I ran 255x85 R16's and LOVED them).
Specs from Nittos website shockingly show very very little difference in weight ratings.
37x11.50 R18's have a Maximum load rating of 3860lbs at 65 PSIG and weigh 76.63lbs
37x12.50 R18's have a Maximum load rating of 3970lbs at 65 PSIG and weigh 83.39lbs
My front axle GAWR is 4800lbs and my rear GAWR is 7050lbs so both tires techically more than cover that. Both tires are approved for the stock 8" wide rim my trucks GVWR is 11,500lbs and my payload capacity is 4214lbs.
The advantages I see on the D rated tire are a likely better ride, a decent amount less rotational mass and the narrow profile I would prefer that also falls more in the middle of the recommended rim sizes, also less likely to throw mud down the side of the truck.
The advantages I see on the E rated tire are likely more puncture resistance on the sidewalls and possibly better ability to hold a bead at lowered pressures (though maybe I have this wrong)
Price isn't a concern as I can't imagine they are much difference.
Which tire is better for my usage? Truck even with the camper will likely never weigh more than 10K but I am still nervous about D rated Tires on a one ton truck. Please help me one way or the other.
