The Adam Blaster
I wish I had some sort of design program that would produce images I could share, but my lack of decent descriptive capabilities will have to be enough for now.
I want to build a small rack that can slide into the receiver hitch on my Jeep Cherokee, or any other vehicle for that matter.
I want to keep as much of my departure angle, so I will have the 2" tube come straight back out of the receiver to the bumper, then 45 up to a straight piece, and that will be the main support for the mounting surface/platform.
I will carry two 2.5 gal jerry cans in the middle, directly over the main "up-tube" and 2 decent sized ammo cans to store a strap and a few d-rings or whatever else.
I'm going to make some sort of strap to come down on top of at least the jerry cans, and find someway of locking the ammo cans to the rack as well - maybe just run a carriage bolt through the bottom...
I'm thinking about making the platform between 30" and 36" long, with approx. a 15" width. I haven't decided on whether I want little sides on it or not.
I've also been thinking about mounting an axe and a shovel to the rack somehow, but those 2 items are not critical to me right now, so I might add the mounts in later.
One feature I want (need) to incorporate is a recovery point at the base of the main tube. Right now I use my receiver as my only rear recovery point, and I can't lose that.
So, I'm looking for any input on the types of materials (size, thickness etc.) that should be used. I'm thinking the 2" tube going into the receiver will have an additional sleeved tube within it to make it a lot stronger for the recovery point. For the frame at the base of the platform I was thinking 1" square tube, and expanded steel welded to it. Maybe some 1" angle to make a seating position for the jerry cans?
Anyways, let me know what you think!
