DONE! Mostly.
Rolled up the sleeves today and tackled the project with somewhat better health. Things were groovy until I couldn't figure out how to remove the AC compressor. Up until then, this Montero Sport video had been very helpful:
https://youtu.be/vunvsjph9Yk (music is a little off-putting). TyTy13 to the rescue. Told me to pull the drivers side tire off and access the 4 bolts that way. Brilliant, but.... I didn't quite have what I needed to reach those tools. So a quick run to the hardware store to pick up some 10" extensions and universal joints and presto, those bolts came out super easy. Makes all the difference in the world when you can get a tool on it!
I completed the full disassembly right about the time Tyson showed up to lend a hand. Did I mention that it was about 95 degrees today? That was so very cool of him to help! He noticed something that I would never have noticed, that the little metal plate behind the crank shaft gear was independent of the crank shaft gear. We (he)removed the crankshaft gear (something that was not on my list to do) and it came off in pieces! He also noticed that the pin that locks the timing from the crankshaft pulley to the gear had sheared off. This was all bad, and I didn't have any spare parts for this. Did I mention how awesome Tyson is? He goes home and pulls one off a spare motor and brings it back, like its no big deal. Holy crap did that save the day!
Other fun facts of discovery. The center bolt on the back plate was rusted along its full length (Nearest the water pump). The (newish) timing belt was literally shredded in places. The water pump bearings literally were dust, and poured out into a powder. Combine all that with a broken ignition timing plate, lose crankshaft bolt, sheared pulley pin, rashed timing belt covers and so forth, it's amazing nothing serious actually happened. It's also a bit of a mystery exactly what did happen, but it should all be good now, so I'm not too worried about it.
We start getting things back together again, and I run off to borrow a decent torque wrench from a distant neighbor, when I come back, Ty had the power steering and AC pumps back on and was working on the alternator (A shiny new one, not a refurb... Alternator #5 if you are counting). Awesome! We used Ty's homemade crankshaft pulley wedger tool and torqued the bolt to 135 ft lbs. Man, that is a lot! I also put locktite on that baby.
At that point, Ty had about 5 hours into the "quick drop by" in the hot weather, gave me some final tips on flushing the radiator, and he was on his way again.
Resolute in my ambition to finish, I pressed on....and managed to do pretty well! As it sits tonight, its 100% back together, even those bastard little clips for the bottom radiator hoses. I have one extra 14mm bolt...hmmmm....
Tomorrow I will get some distilled water and a flush kit and then I should be good to go. I'm not sure who's more excited, me for having gone through this, or my son who will get his daily driver back!
In summary, the work was actually fun. Also, it totally helps to be able to breathe and not feel like dying! I spent about $550 on OEM parts (not including the $350 water pump!) and then got a timing belt kit at PepBoys for $150 with everything, even gaskets.
I get to take back all the OEM stuff (except the crank bolt and washer), so all told, I think I'll have spent about $300, including tools and fluids, and a new radiator cap. Dealer wanted $1,200. Honestly, that's a fair value given the work involved, but since I didn't have that kind of money available, doing it at home was a much better and more valuable experience.
Upon reflection, I am surprised I had most of all the tools I needed, though i did need to add to my ratchet kit with longer extensions and universals. I can see getting swivel sockets in my future....
I made good use of my Christmas-formyself gift:
But really, most everything was with hand tools and ratchets sets. I used 10mm, 12mm, and 14mm for most everything, and 22mm for the crank bolt. Thank God for gear wrenches. Those little 10mm fan nuts are a total PIA, even with the right tool!
