So to continue, I have penciled down a few things to better equip with our rigs with. Not complete. In no particular order:
1. After picking up both Land Rovers (leaning towards the Surveillance model now) I will have KLR fit them with Power Steering.
2. KLR to install door locks.
3. inspect, repack/replace axle bearings.
4. Install in rear axle a Deroit Locker. Front Axle will get the Ashcroft Air Locker.
5. Install Hi Tuff and or Ashcroft axles, stub axles, cvs, U joints and flanges ect.
6. All new suspension bushings.
7. Koni Raid Shocks (unless something better comes up).
8. Not sure if the wheels use tubes or not. If so then all new tubes. If not add Staun bead locks.
9. All 6 tires balanced (2 spare per rig).
10. All new brakes, brake hoses and brake cylinders ect..
11. Diff protectors and skid plates as needed.
12. All fluids to be changed.
13. All filters to be changed.
14. All new belts and hoses (one complete extra set as spares).
15. All suspension nuts to be re torqued and lock tightened.
16. NUGGET's Diff breather.
17. Install larger fuel tanks (200 liters plus combined).
18. Install 3 to 4, 67 liter water tanks per vehicle. Secured to rear floor and plumbed for easy fill and dispensing (electric pump).
19. Hot water shower unit.
20. install hard top (cab).
21. Custom Canvas Work to rear area cover.
22. Rhino Line rear bed area.
23. Dynamat cab floor, walls and ceiling.
24. Boom Mat Floor.
25. Install stock rubber floor covering.
26. Custom canvas work for seat covers, tire covers and other items.
27. Install Air Compressor and tank. Sealed for water crossings.
28. Ham Radios installed in each vehicle.
29. 2 solar panels mounted on roof. These charge two Oddessey Batteries completely separate from vehicle electrical system. These power non vehicle related accessories.
30. All batteries changed to Oddessey Batteries.
31. Install Freeze Fridge (largest possible).
32. Synthetic Rope installed in place of wire rope.
33. Sat Phone per vehicle.
34. SPOT tracker per vehicle.
35. GPS per vehicle.
36. Engine mechanical fan to be removed and replaced with electrical fans (an off switch used for water crossings). Open to suggestions on this.
37. Nugget Light Guards.
38. Rock Sliders.
