F150 tire size?
I'm running 35x11.5R 20 AT3's with a 2" level on stock wheels.
Very slight rub on pass side in full lock in reverse. So really doesn't occur that often.
I have a level as well so it is great to hear that is what you are running and it works. Only difference is I am using Raptor takeoffs which have +34 offset versus stocks +44 offset.
I ran 285/75/17 on Raptor takeoffs with no rubbing. It even fit in the spare location- just barely. 2015 F150 but they are the same as 2018, pretty sure.
Can you post some photos of your 285/75/17 on Raptor takeoffs? I have 315's on Raptor takeoffs and am considering going down to 285 size but would like to see what it looks like first if possible :)
Here are some examples for you. The truck has been leveled. The stock rims in the first pic have a +44 offset. The other two pics have raptor rims with a +34 offset. The larger tires would rub without the -10 offset. I hope this helps. Not that the last pic is with a RAS system installed so it looks higher in the back. I have since removed the RAS and I do not have any rubbing issues.
Stock
285/75R17
35x11.5x17
Dynamo TCX
