buck moberly
I finally found crane for my fg. The crane has a 6000lb capacity, is all electric and weights 1400lb. I have it mounted, well on the truck with the subframe for the crane and outriggers finished. I have misplaced the big nuts and bolts needed to bolt it down but it is on the truck and I now have to level the truck and could use a few opinions.
First, do the Timbren rear bump stops make contact all the time? Could I shim one side to level the side to side load? With the crane on the truck one side is about an inch lower than the other side and the low side is a inch from stock bump stop to axle.
Second will 35.4" tires ie. 285/70r19.5 srw conversion fit with the stock suspension? I want to try the Toyo m-608z tires. Suggestions?
