flyingwil said:...
It really is a shame... So have any companies produced a "fix" similar to the Demello frame reinforcements on the Taco's?
cruiseroutfit said:I havn't seen a fix kit yet... with all the suspension, steering and motor mounts/brackets and components on the front of the frame... it would require ALOT of work to install something like that.
teotwaki said:...Note that only three vehicles on the whole forum have reported cracks.
cruiseroutfit said:Where are you seeing that number? I read through just a handful of pages and noted at least a half dozen forum members with issues. I know of at least one major case here in SLC with the body rip. He is currently working with his dealer to resolve the issue. As of late Toyota has changed things up on the newer models with a different inner fender? Some on the FJ Cruiser Forum think a TSB might even be issued??
teotwaki said:Post # 10 on 8-11-07
Re: Engine Bay Body Rips
With only 3 of these reported out of all the FJs on the forum. It would really be nice to hear the whole story on this. This is fishy. Lot's of us wheel extensively, with the same options, and no trouble. Physics isn't random. Is there any more you might be able to tell us? It might be a rare metal defect, but it's hard to imagine.
cruiseroutfit said:Oh, I think his number was a bit premature Keep reading, there are over 1100 posts after that one. Look at the poll at the top, while its likely not accurate... it shows an alarming number of instances.
SOCALFJ said:Why would the body rip like that? The bumper isn't bolted to the body, its bolted the frame. Im confused!?
flyingwil said:In Farmington on this winch pull the bumper was tweeked a good inch at the end of the pull:
TrAiLbUs1 said:eventually there will be service bulletin or a recall of some sort.
