mr_ed
Toolbag
**FIXED! See bottom**
**PROBLEM BACK! See bottom**
So my '98 Gen 2.5 developed a crack in it's fuel tank. Long story short I dropped the skid plate and tried the cheap-route, "apply even while it's wet," magic gas tank fix. Lasted 10 minutes. Drained and dropped the tank and applied JB Weld and let it set overnight. Lasted long enough for me to get way up into the Olympic mountains before it started leaking again. Drained and dropped a second time, and tried actually welding it (not to worry, I filled it with water :snorkel: so I'm still among the living) which didn't work cuz I suck at welding sheet metal, so I used some high-quality fuel tank repair epoxy. This lasted long enough for me to get up into the Mt. Hood National Forest before it started leaking again. So I'm done with pipe-dream tank repairs and am on the prowl for a new (used) tank.
My question it, will a tank from a Gen2 fit into a Gen2.5?? I've checked on oemmitsubishiparts.com and the part # is different from a 1998 to a 1997 and older, but that doesn't necessarily mean that it won't fit. My wife has a 97 LS and from what I can tell just from looking at it they appear the same.
Just curious if anybody knows for sure. Real Monteros are hard enough to come by in the wrecking yards up here around Portland OR (ones that aren't a dang "sport") and the Gen2.5's are scarce as hen's teeth.
Thanks for any help. I really want to get this fixed for sure and for certain. I can't take it anywhere until then cuz I'm paranoid someone'll toss a cig butt under there and suddenly :Wow1::Wow1:
Cheers,
Ed
Cheers,
Ed
