Gen 2 or 2.5 MPG?
PacS14
This info is readily available online.
That's my point it is here, but in between a lot of clutter. I just suggested to have a sticky about gear ratios on the front page. I'm not in a rush to do the swap yet, I'm sure I will find it when I need it.
Before you ask I used the search option here, Google, and 4x4 wire after one hour I was like I don't need the info that bad right now and quit. I'm sure I would have found it eventually, but I'm sure having a tech about all years and trims available would help more than just having a sticky about the Gen 2.5 and that comes from a Gen 2.5 owner.
jeep-N-montero
Here you go https://www.google.com/search?q=montero+gear+swap&ie=utf-8&oe=utf-8
jeep-N-montero
Thank you Jeep-N-montero that's what I need it, I did not mean to be spoon fed the answer. I just think having a tech sticky about each generation would be helpful.
Sometimes just typing in the right key words gets it done right away, helps too when you have been doing this stuff since 1999.
magoh76
I agree we need better organization of info. Searching with proper key words is key (heh), but sometimes you don't know the key words to use. Stickies can be a nice friendly way to organize information that is spread throughout several threads and sometimes contradictory from thread-to-thread.
I like the sticky with part numbers for Gen 2.5, similar threads for each generation would be useful. Also useful would be a sticky that collected threads describing common problems and fixes.
I know, be the change you want see :)
BOPOH
I would love if they made DIY sticky, build threads are nice but DIYs are way more beneficial - unless there is a sticky and i haven't seen it yet
Goldenbora
