Ham radios. What is everyone using
HenryJ
So how exactly does aprs work?
Sent from my PG86100 using Tapatalk 2
http://www.aprs.org/
The Automatic Packet Reporting System was designed to support rapid, reliable exchange of information for local, tactical real-time information, events or nets. The concept, which dates back to the mid 1980's, is that all relevant information is transmitted immediately to everyone in the net and every station captures that information for consistent and standard display to all participants. Information was refreshed redundantly but at a decaying rate so that old information was updated less frequently than new info. Since the primary objective is consistent exchange of information between everyone, APRS established standard formats not only for the transmission of POSITION, STATUS, MESSAGES, and QUERIES, it also establishes guidelines for display so that users of different systems will still see the same consistent information displayed in a consistent manner (independent of the particular display or mapping system in use). APRS was never intended to be just a vehicle tracking system (GPS was added in the 1992 time frame when GPS became affordable). APRS is much more.
I am ashamed to say I just use it for vehicle tracking. :( Works great though :)
Check it out: http://aprs.fi/#!lat=44.08610&lng=-117.01880
DaveInDenver
Middle Income Semi-Redneck
Does aprs report through any repeater?
Are you asking if every repeater is capable of acting like a gateway to APRS.fi? No, there's usually only a couple of IGates in an area, although there are likely many digipeaters (digital repeaters) capable of retransmitting APRS packets. So even if your location packet does not make it to the Internet it will get bounced around a couple of times locally.
DaveInDenver
The Micro-Trak sounds interesting. It would be nice to use my existing 2M antenna though. Anyone have experience with how to setup a single antenna with two radios?
Two VHF radios operating in fairly close frequency into one antenna will only work with a switch or a very deep notch duplexer like you'd find in a repeater. Some radios are able to run simultaneous VHF TX/RX by using a quasi-smart switch/duplexer. For example the FTM-350 can autonomously transmit an APRS packet but before doing this it blanks the other side to avoid harming it. Others like the FT-8800 have a built-in duplexer but the secondary (non-TX selected) side cannot transmit on its own. If you want to run both a voice and packet radio at the same time you need two radios & antennas or a radio that is designed for this (FTM-350, TM-D710 are the two most common) to take care of the multiplexing duties for you. Realize that with the FTM-350 (and I assume the TM-D710) when the APRS radio is TX'ing, the other side is quiet. It's smart enough to skip the packet TX if you are talking on the other side, but if you are listening the RX will go quiet for a second or two.
1911
No; 99.8% of APRS (in the U.S.) is done on 144.390 MHz simplex. 2m repeaters have their own locally-unique frequency pairs so that they don't interfere with each other or with the APRS frequency. APRS beacons are propagated by other APRS stations acting as digipeaters, until the digipeated beacon reaches an IGate (internet gateway). However, there are a fair number of digipeaters and IGates installed on towers along with ordinary repeaters. One thing I like about my APRS setup is that it shows me all the IGates and digipeaters as unique icons on my GPS screen, so I can always tell how far away and how high the nearest one is.
08BrickFJC
FTM-350 w/the GPS module installed and a Diamond Tri-band antenna on a pivoting mount. Still learning the radio/APRS...amazing functionality
:coffee:
ldivinag
started out with a VX-7R.
until it started to have issues. i still have to send it back to yaesu to get it fixed.
bought a wouxun unit to make sure i have 2m/70cm capabilities.
recently bought a byonics AIO aprs unit. really cool toy. sends OUT only so...
rho
Lost again
FT60r for everything at the moment. I have a ft1900r to go into the jeep at some point. Just have to figure out where to stick the radio...
wheelerdh
K4WHE
I once had a ft-8800 and it was a great radio, only reason I sold it was to vet the ftm-350r for the APRS functionality. It does great as well and the GPS portion runs through a Garmin Nuvi so I can see stations on the map. Also running a ft-857 with an ATAS-120 antenna. Got the bases covered :)
BulletHead
Do handheld units (or non-handheld) exist that would be for HF, VHF and UHF? I'm trying to see if I can buy just 1 for use with the CB as well as Ham.
srch4me
Cb is am radio band. Ham is FM. generally its best to have a separate radio for each.
KF7ZSK
JPT4648
