Harbor Freight $9 receiver tow hook
adventureduo
Dave Druck [KI6LBB]
If anyone needs one.. may be good for one pull only since it's from Harbor Freight lol
But hey $9.99, Can't beat that!
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=95594
***NOTE*** it's rated for 10,000 lbs
DaveInDenver said:
That would be my first reaction, to run away. Wonder if anyone has seen it up close?
I have. 4Wheel Parts carries them. If anything I would say they are more frightening in person. The actual part is much lighter in weight then that one looks to be.
I'd rather have the one from Northern. It's pretty heavy and substantial to hold in your hand. Costs more, but I believe you're paying for more.
Harbor Freight = Cheapo Knock-off Norther Tool Not bad for some things, but not good for all. Just my .02.
DaveInDenver said:
This one seems perfectly fine (just don't get impaled on it!).
Doesn't hurt that it has this, too:
That's the one I want if I ever loose a hand.
FWIW I've never seen any utility in a hook. Too many hard and soft failure modes. Much prefer a shackle type adapter.
The one I built for myself is a weldment, but none of the welds see any of the load, all they do is hold the pieces in position. Mechanical interlocking distributes the loads.
Some folks claim to just use the hitch pin inside the receiver. I've tried that, and it only works with a singled pull. If you need to double the strap to shorten it that doesn't work as there isn't room inside the receiver for more than one strap.
This methods works and is safe. Like you mention, space inside the hole is a premium and you gotta be aware of sharp edges around the receiver itself. It's also works less good off angle. But it is a perfectly acceptable solution and one that works in a pinch without a ton of risk. IOW, I would far and away rather see a draw bar pin recovery point than one of these welded grenades-in-waiting.
empireoverlandza
