Hilift PullPal Adapter
ntsqd
Heretic Car Camper
Lynn said:
I have to ask, though: isn't the potential load in the pulling scenario much greater than the potential load in the jacking scenario? Did you take that into account?
I did consider that the bearing load and the tear-out stress would be a potential issue due to the way (where & how) that you would have to attach a winch cable to the beam. The Hi-Lift 8k limit is imposed by Hi-Lift through the shear pin. That limit applies whether lifting or winching since the shear pin doesn't care. If the winch in question is 8k or less, and is not doubled back to the vehicle, then you're within the design limits with the attachment. If it is more than 8k or doubled, then you're treading out there where the ice could be thin depending on what the Factor of Safety for the beam's holes are and how hard you pull on it.
My instinct still tells me that it would be pretty easy to twist or bend the beam if the spade happened to dig in at an angle (other than perpendicular to the beam), like if it hit a rock, a hard spot in the ground, or if the vehicle happened to move sideways during the pull. I know from experience (read: misuse of a hilift jack) that it's not hard to bend a beam.
Keep in mind that excepting Kurt's picture that most bent Hi-Lift beams happen in compression. Pretty hard to pull something bent. Can be done, but takes an exceptional special case scenario to do it. In a tensile loading the only directly applied bending force is from the triangulation brace that attaches to the beam's midspan and the tube holding the spade. This loading is in the best possible direction for an I beam shape.
So then the only way to apply a bending force would be if a rock or something else underground skews the spade enough to try to twist the whole device. There is not a lot of leverage there, and it would take other rocks bearing on the device in a certain way for it to turn against the direction of the cable's tension. Any bend then would be operator error or abuse.
Should you damage it enough, then, like cruiseroutfit mentioned, you no longer have an anchor OR a jack.
That is a potential downside. It takes a lot to bend one permanently. I've seen a 60 inch version with over a foot of bow in it, and it came right back once the load was removed.
cruiseroutfit said:
Sure, the entire Pull-Pal represents a lot of weight, but I'd guess that the beam itself isn't going to save you more than 10lbs. Consider my complete Pull-Pall weights 34lbs, 36lbs with the case... add to that I don't carry a Hi-Lift (26lbs) rather a exhaust jack (15 lbs)... I'm at a net savings. Not that I'm honestly ever worried about 10 lbs in a 7500lb setup :D
As someone who has quit carrying a Hi-lift as well I'd also be gaining weight. I'd have to carry a second Hi-Lift too, no winch.
10 lbs would mean that you're now at 7490, a step in the right direction. ;)
cruiseroutfit
ntsqd said:
...As someone who has quit carrying a Hi-lift as well I'd also be gaining weight. I'd have to carry a second Hi-Lift too, no winch.
I need to revise that a bit, I started weighing things on the shipping scale :p
Pull-Pal & case actual weight - 29.2 lbs
Exhaust Jack actual - 15.4 lbs
Hi-Lift actual - 26.6 lbs
We really need someone to measure the weight of the "hi-lift" style Pull-Pal, I have a hunch that it weighs more than the complete Pull-Pal unit given its minimum thickness of 3/16" (Pull-Pal is 1/8" in designed areas).
Oh yeah, the weight of the Pull-Pal bar that is essentially replaced by the hi-lift beam: 6.82 lbs :D
(yes I'm a nerd and I pulled one apart)
Pic 1: The removed bar of the Pull-Pal
Pic 2: The scale reading
Pic 3: Pull-Pal bar versus the Hi-Lift
ntsqd
Heretic Car Camper
Pull-Pal weight: After hefting the first one that I gave away I knew that I'd be giving away the second when it came my way too. To be fair, both were still in their boxes. No idea what they actually weigh or if there was anything in the box of significant mass that wouldn't need to go with in the vehicle.
Nerds of the World, Unite! :)
What about space considerations? Could be a deal breaker, but it doesn't sem like it would be all that much difference.
cruiseroutfit
ntsqd said:
...What about space considerations? Could be a deal breaker, but it doesn't sem like it would be all that much difference.
Space is a definite issue. Short of hard mounting to a roll-cage or bed, its another thing taking up precious space. With the Pull-Pal patented desing, it folds pretty flat (~40"x10" - 2" thick). However some of the knock-off designs I've seen do not offer the portability and stowage, could easily become a hindrance.
madizell
The blade on the Pull Pal is removable, so that the main frame assembly can be stored in a space not unlike the space needed for a Hi-Lift, and the blade can go just about anywhere as it lies fairly close to flat (there is a stamped chevron in the blade so it is not perfectly flat.) 35 pounds sounds about right for one of the bigger units.
I would not use a Hi-Lift beam as the main frame of a Pull-Pal knock off. Off angle pulls are not impossible in the field, and side loads on the lift beam would permanently damage the beam, which is not cheap to start with, nor are they light in weight. I have bent, broken, and repaired various parts of my Pull-Pal more than once due to difficult recoveries, although I have never damaged the shovel part, which is about as indestructible as a piece of metal can be. I have bent the main beam and have torn out the supports on a 14,000 pound PP, so it can be done even with a 5,300 pound vehicle and an 8,000 pound winch. The twist on the beam comes less from the shovel striking something under ground as from the vehicle changing relation to the anchor point during recovery. Expect some degree of off-angle pull in all but the most simple of recoveries.
While on the topic, burying a Pull-Pal in soft sand is not a problem, and in fact is frequently necessary in order to provide enough anchor force to recover a vehicle. If you expect to use an anchor in sand, attach a tree-saver or length of rope to the tail of the anchor so that when you are ready to recover the anchor, you have something to pull against in the opposite direction from which the anchor was buried. Back up to the buried anchor from behind the line of pull that buried it, attach the strap of rope to a shackle point on the bumper and drive away slowly. The anchor will come right out as a rule. Beats breaking your back trying to lift it out any other way.
cruiseroutfit
madizell said:
.... If you expect to use an anchor in sand, attach a tree-saver or length of rope to the tail of the anchor so that when you are ready to recover the anchor, you have something to pull against in the opposite direction from which the anchor was buried...
Great idea! One could even get a short piece of cable made with a clean attachment point at the Pull-Pal and a crimped loop at the other. I'm going to have to look into that.
madizell
If you get the chance, watch some of the Outback Challenge video, available through Overland Journal's video sales, and you will see lots of guys recovering anchors from sand. What works becomes obvious as you watch, and they are great videos.
