Grim Reaper
I completly flaked. The lower the NOX the higher the fuel content. Dave cought it. Non function EGR is the first place to check and a very common issue on toyota.
I have not worked on the 3VZ but most of the Toyota EGRs I have worked on are set up simular to this and you should be able to test the EGR with a vacuum gage and not much else on your own.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=EC&P=16
