jeep4x4greg
Quick update: I do have water in my cylinders, I pulled a couple spark plugs and looked in with a flash light and could see liquid inside there. I also checked my old oil and it appears to be fine, nothing out of the ordinary just dirty and old (been about 5000 miles since last change so it is time for that any way). I got the battery off and checked the voltage and it was just barely over 6 volts so it is on the charger right now. Hopefully once that is charged I can pull all the plugs and turn it over and get the water out!
you can also pull the plugs and rotate the engine by hand if you are able to reach on an XJ.... I know on a TJ you can do it if you reach down and turn the crank pully. this would be better than letting it sit with all that water in there....or pull a battery from a friends car and do it with his battery. the less time the water is in there the better.
also...your oil may look ok....but change it twice anyways.
