Like I said earlier, the cooling systems as built by land rover are very robust and can handle the hottest weather on the planet but that is very much dependent on the system working correctly and all the components to be in good shape to perform their function in the complete system.
That's the important thing to take from this. In good working order (maintained, but not brand new), the cooling on Land Rovers is perfectly capable of cooling the vehicle rgardless of what you're doing with it or where.
Some people like to fit electric fans to replace the viscous fan, but I think that's a big mistake. The engine driven fan has much higher capacity and power, and is more reliable than an electric fan. Engine remanufacturers like Turner Engineering and ACR warranty their engines for 12 months, but the warranty is voided immediately if the engine is run without its standard fan.
If you have a good look around modern quality cars, you'll find that electric fans tend mostly to be used where the engine is mounted transverse. Most in-line engines will have engine driven fans. Electric fans tend to be used where fitting mechanically propelled fans is impossible.
As for the effieciency of electric fans, I'm disinclined to believe the claims of the manufacturers. When you're driving along, the fan is not needed. An electric fan will stop, while an engine driven fan will continue to be spun. However, since the fan blades will have little angle of attack on the ram air through the rad, it will have very little drag. This is even more the case with viscous fans, whos' little remaining drag when "slipping" will be almost entirely offste by the ram airflow, so the drag would be vitually nil. When slow or stationary, the fan will cut in, and an engine driven fan is not only more effective than an electric fan, but also consumes less power as it puts no strain on the electrical system - an electric fan has to use engine energy turned into electrical power by the alternator ans back into kinetic energy by the fan motor, which is a very inefficient power transfer.
I had no choice but to fit an electric fan to my 109, but my Tdi RRC will never lose its viscous unit. A supplementary electric fan to assist the viscous unit may benefit some people, mainly just their paranoia, but it shouldn't be necessary, and certainly shouldn't be used to replace a stock system, in my opinion.
