Improved Engine Cooling?
michaelgroves
It's there to make it hard to recover any nuts, bolts, washers, etc. that you drop from above.
Seriously, I have no idea why they put that stuff on. Lose it, unless someone else knows a good reason to keep it.
Geo14cux
Put it back on! Thats not how the engineers intended it.:coffee:
greenmeanie
The belly pans under the engine bay are usually put there for sound proofing reasons. There is a suprising amount of sound reflection down from the engine off the road surface and into the cabin area. The engineer intended it to be that way to meet a requirement driven by the luxury market that the SUV is aimed at. It is pretty much uneccessary if you don't mind a little extra noise.
It does perform one useful function by catching the various fluid leaks from the engine bay and saving your driveway.
R_Lefebvre
One of my favorite techs I used to work with used to say "The bolt fell into an alternate dimension." I always chuckled at that.
Only until it overflows... and then it makes it harder to trace the leak... ;)
Goldenbora
