Eezi Awn Cover Update
I wanted to give an update to this thread regarding a discussion I had with Eezi Awn and the concerns we are seeing in the US market.
The only change that Eezi Awn has done to their covers in the timeframe of our relationship is to increase the UV rating from 5 years to 7 years. This took the material to a 700 gram thickness. I was informed that this is more than 150 grams thicker that any other cover on the market currently. The gram increase also modified the finish of the material. The earlier covers had a single finished side, where the newer ones have both sides of the material finished. This had the effect of making the material a lot more plyable. It is not that the material is thinner, it's just not as stiff.
Eezi Awn also requested that their supplier be able to integrate the use of 2 meter wide material, up from the 1.5 meter material they were using. This was to decrease the seams on the top of the covers. This adjustment required 10 million Rand equipment upgrade on the part of their supplier.
The reinforced corners in the covers has been limited to the larger models and T-Top specifically. The covers I have do not include the corner reinforcements, but are made of the higher grade fabric.
The stitching thread on the covers is rated to 50 degrees C with out degredation. This is roughly 122 degrees F. They close the mitered corner of the strap around the lower perimeter and sew across it twice, then cut the miter to open it up again. This process will allow some stiches to open, but is stronger than stopping at each miter.
The covers are designed to be a perishable, and something that will need replacement over time. It sees the harshness of the sun, the errant branch, and the nasty brunt of a types of weather. Depending on the use, a cover has a lifetime. It protects the real asset, your tent. That is why we carry extras.
Eezi Awn assured me that they are responding to the concerns of our market. They haven't heard these issues from their other world markets, but understands that doesn't dilute their importance. We are working on several advancements with regard to the stitching and corner protection to the covers for upcoming inventory to the US.
I hope this helps to increase the understanding of cover construction. I will let you know if any more developments come about.
Thanks,
