Jevy's humble M-416 build thread
DonBeasley
Bearings should be easy to find local. Do you have the parts numbers for these?
Federal-Mogul:
Bearing: LM501349
Race: LM501310
Grease Seals (2 per trailer):
Federal-Mogul 472018
BTW it looks great!!!!!!! Now if only your back was good enough to load it/unload it and climb in the RTT (LOL)
Jevy
Don....
I have those numbers from a website somewhere and couldn't find it again. Thanks for the part numbers!!!!
Federal-Mogul:
Bearing: LM501349
Race: LM501310
Jevy
I also forgot to point out one kind of a big deal to me: I used the space on the back for the water/propane for where I planned to mount my generator. I'm hoping I can put it on one of the sides in front of the fender. I will try to fit it tomorrow to see if that will work. If not then honestly I don't know what I'm going to do. Since I have had back surgery I try to not lift anything any more than possible. I know I'm not going to put it in/out of the trailer when on a trip. I gotta figure something out where I don't have to pick it up into the trailer. Since I did the axle flip/35" tires it's too tall to make that task a reasonable one.
Jevy
just a small update. At this point I have the following to do to "complete" the build......at least for the time being.
1. I have the bearings and seals. I'm waiting for a bearing grease packer tool that i should have next week.
2. Wiring from the Jeep to the trailer for charging off of the engine while in tow. It is being installed to the rear of the Jeep and I only lack a hour or so to finish it. I have not ordered the wire yet and it's not real high on my priority list so I'll get to before spring.
3. Honda generator mount......I can't figure out what to do and I'm really disappointed because this was a high priority for me. I may end up removing the rotopax to mount the generator. If I had to I can mount the rotopax on the inside of the trailer(again not an optimal choice or solution.)
4. Monstaliner. I've decided to wait around the first of March to do the monstaliner. The weather will be warmer and I'll be in a position ready to apply it and cover up a few blemishes that the Jeep has from all of the work I've done this winter.
I'm going to be watching the weather forecasts and if we get a decent weekend I hope to take both the trailer and Jeep out for a shakedown run.
Jevy
today I took the center caps for the axle and used a wire brush on a bench grinder to remove the 20 layers of paint that were on them lol. My son did the second one then took a dremel with a wire brush to the inside of the caps to remove any old rust or trash. We also took the dremel and cleaned up the insides of the hub and the spindle axle shaft.
I removed the safety chains from the original place and moved them out towards the end of the extended tongue. The only way I can figure it out to mount the honda outside of the trailer without changing a bunch of things is to mount the generator on the tongue in front of the tongue box but I got to thinking that I also do not have a way to carry a cooler on the outside of the trailer. I'm going to have to take a step back and re think how to make it all fit.
DonBeasley
It is amazing how quickly that trailer fills ups. When I started I thought that I would have tons of room and now I am thinking of what I can take out to make sure everything fits!!!
Glad it is coming along.
01greentaco
Jevy, as weird as this sounds, as I was looking through your build thread and the architecture and style of the houses immediately made me think of Memphis. I am from Collierville myself and have been working on my own M416 the past few months and let me tell you, you have given me so many ideas and directions in which to take mine. It looks GREAT!
Here is a before and a most recent shot of my project M416:
Jevy
small world lol. If you want to come look at it then you are welcome to. I am really close on finishing it up. The trailer will be done with practically everything on my list by the end of the week with the exception of the monstaliner.
Seriously if you want to come see it just let me know. I'm also very close to finishing my Jeep as well. I hope to have it done by the weekend as well. Friday I am picking up a military truck to start messing with a little. I can't wait for spring to get here where I can get outside some. I'm hoping to do some of the transamerican trail this year. We also camp a few times a year over in the Mountain View AR area.
01greentaco
I am in my Junior year at Mississippi State, but I'll be home in a few weeks. I'd love to stop by and look at yours, see some of your modifications in person. I'll let you know when I'm back in the area. Thanks!
-Michael D.
Tumbleweed
Jevy, nice build and I can share the pain of a ruptured disc surgery. Mine was done in Nov. and just now able to return to work. Some thoughts for you to consider in no order.
The marker lights in the lid are all amber, shoudn't the rear most ones be red?
On the taillights, a little silicone where the plug goes into the light will help seal it from moisture but will also keep the plug from coming loose.
On your trailer tongue, can you drill more 5/8 holes so you can slide the tongue shorter if needed? Would make garage storing easier and might work better on a tight trail.
Keep an old set of your wheel bearings for spares; clean them and grease them so they are ready to use; and bag them in a ziplock.
When you wire your trailer tongue: put a quick disconnect plug on both ends of the tongue so you can remove the wires when not in use. They always get cut or damaged when left on and the trailer is parked no matter how careful you are. Mine wound up being squirrel chew toys. Store it in your tongue box.
Along the tongue, you can weld a chain link now and then with a 1/4" cut in it to hold the wiring in place. Just tuck the wiring in when you use it.
For lighting inside the tongue box and lid, those led touch puck lights like Harbor Freight and hardware stores sell work well. Battey powered and last quite awhile/ and no wiring. Just stick on. I do prefer the ones that roll/tilt a bit for adjustability. ( A white lid or interior really helps with lighting)
Safety chains. I like to weld two chain links to the frame, and then use a quick disconnect chain link to attach the chains with. That way, I don't leave an easy way for someone to steal the trailer even if I remove the tongue. And, I can use the chains to padlock up whatever if needed-i.e. a generator or such. Always find a use for a couple 4' chains. If needed, locking the trailer to a tree is easy enough with a padlock or two. I use 5/16" chain so I can get a bolt or padlock through it.
Agree on the no permanent water tank idea. I like to just carry water jugs and have the portability and ease of filling. I have never stayed out long enough to need anything more than a "bird bath" for a shower.
Tailgates. I love a tailgate; however you lose alot of stability when you have one with a roof top tent. The tub flexes alot. If you go to one, plan your lid support strut mounts ahead of time.
Fridge slide out. Could you built a new tongue box that would encase your fridge and slide out, saving to cut the tub up?
Hilift mounting. Two 1/2" bolts with winguts and washers will secure a hilift whereever you can fit it. Short cable to lock it up. Just put them through the I beam of the jack.
I will quit rambling for now, good luck with your back recovery and builds.
Jevy
TW.....my rupture was bilateral which rarely happens and the doc told me basically that I will never be the same again. I'm ok with it. I have just had to change some priorities.
My rear lights are red but the ones on the sides are orange. I pretty much agree with what all you said. Most of our camping will be at campgrounds that are primitive but usually water is available. I have a harbor freight tongue box and quite honestly I don't want to change anything with that. I'm not much of a carpenter and I would seriously question whether I could make a slide out fridge that would be robust enough, secure enough, and a clean finished product. If I were to put a tailgate into anything it would probably be the Jeep itself but I just don't want to do that(although my mind may change after using it some).
I had already planned on saving the old bearings and there isn't anything wrong with them that I can see. I went ahead and ordered replacements for piece of mind. I'm waiting on the bearing packing tool to show up so I have not messed with the bearings yet. Tomorrow I plan on making a rack on the tongue to hold the generator and maybe do the bearings if the tool comes in. I also had an issue with my Jeep today so I have to replace a brake line so I may put that ahead of finishing the trailer.
Jevy
ok so I'm proud to say that my Jeep build is finally complete!!!!
I may start in on finishing up the trailer tomorrow but if not I'll definitely get started on it Monday. Next on the list is putting in the new wheel bearings and then I have a couple things to figure out.
1. Make a generator mount for the front of the trailer.
2. how to mount a cooler on the outside and/or relocate the rotopax
3. monstaliner but it will likely wait until warmer weather
After that all I need is two new tires.
DanoWall
