Lets See Your Solar Setups
Off Grid engineering dual battery kit. One Odyssey 34r and one Bosch 35. 100w suitcase by Renogy and the solar charge controller is Victron 75/15 with the bluetooth built in.
deweycj7
Two 50W generic semi-flexible panels wired in parallel and a 20Ah LiFePo4 battery to run the fridge. So much better than having to restock an ice chest in central Baja...
DaveInDenver
Middle Income Semi-Redneck
Great! IP 43 is still pretty watertight fitting in a dry location.
IP43 isn't watertight. It's splash proof up to 60 degrees from vertical, normally meaning it's OK to be in the rain as long as it's installed oriented correctly. It's also not dust resistant at all. It will be resistant to objects 1mm or larger, e.g. it will not be possible to jam a screw driver into it.
http://www.dsmt.com/resources/ip-rating-chart/
Under the hood that's probably OK, though IP54 would probably be preferred. The advantage to not being well sealed is it'll probably handle heat better, though.
john61ct
Sorry, got it off a distributor site once I couldn't find it directly.
Still, I bet compared to the other mainstream full-featured brands, better than most.
dreadlocks
yeah I personally would not worry water at that location, not unless yeh got snorkels.. I would be concerned about dust, but just enough to hit it with an air compressor every time I was in for an oil change..
now if it was one of the $400-800 charge controllers, and not a $100 one.. then i'd be a bit more concerned about putting it in the engine bay.
flipstick
