elcoyote said:
It could be done but then you would lose the potential to store something in that little spot. I can think of a few things that might fit neatly in there like my coveralls etc.
I agree, I think that 2" slot would be very handy.
I am a bit concerned about the dimensions quoted above. The Tuffy website shows dimensions that are a bit lower and a bit shorter in depth. My truck's measurements (2005 LJ Rubicon) seem to be closer to the Tuffy's measurements than the ones stated by Roadkill
Per:
http://www.tuffyproducts.com/p-182-131-lj-unlimited-security-drawer.aspx
20
1/8”L, Box 34 1/4”W, Overall 53 1/4” W,
11 3/4”H
Looking at the photos I posted, this seems right, because the seat back continues to slope above the 8" transition mark indicated. If 6" drawer is the lowest profile you'll fabricate at this time, then let's agree on 6, and reduce the proposed dimension 1/4" accordingly (I really want it lower!
Therefore, I think the final measurements should be:
LJ 85
Ext 8
.50"H x 34.25"W x 20.
25"L
Int
6.00"H x 29.75"W x 18"L
(keep the same?)
Single drawer, 250lb rated slides, locking slam catch
Wt 32 lbs $465
LJ 12
Ext 12"H x 34.25"W x 20.
25"L
Int 10.25"H x 29.75"W x 18"L
(keep the same?)
Wt 37 lbs $505
I'm amazed at the difference in weights! Mario posted. Tuffy quotes a 97 pound shipping weight, without dividers!
Speaking of dividers, is this an availabe option? With this width (29.75"), it seems that having 3 grooves slotted into the 3/4" composite panels, dividing the load space into quarters would be very cool. 3/4" dividers seems a bit overkill, but maybe 1/2" material could be used as dividers?
