M716 into a Camp Trailer
matthewp
Combat Truck Monkey
Thanks Matthew. I used LED light bars from Super Bright LEDs. They are permanently attached inside the ARB awning with VHB tape. The wires run out a small hole drilled in the aluminum frame. They are here:http://www.superbrightleds.com/more...h-power-led-waterproof-light-bar-fixture/680/ I put in two each of the 60cm model. I will try to get detail pix when I return home- if they would help.
Cheers,
Greg
That's absolutely great info Greg! Thank you very much!
Jevy
wow you have done an AWESOME job!!!! You've made my trailer look like a tinker toy. I wish I had your fabrication skills. Any chance you could give more info on you slides and some pics of when they were being fabbed up??
shermantank55
Maiden Voyage
Got a chance to take the trailer out for a short trip. No issues with stability on the road and tows like its not there. Everything worked like it was supposed to and my son and I had it set up and ready in just a few minutes including the hot water heater and kitchen with awning.
Some pics:
iStan814
