"Manual Backup" for Water Supply
matthewp
Combat Truck Monkey
I'm having a connundrum about whether I should have a gravity-fed spigot from my water tank as a back up. I'm setting up with an on-demand pump but have a nagging concern it wouldn't hurt to have a plan-B in case my pump goes out. There is an extra output already in the tank and I haven't finished the bodywork to the back yet, so adding this would be no issue at all.
What say you all?
Texan
I hadn't thought of a backup, but I agree with a drain. Slower, but you need to drain it for winter storage anyway. I was going to put in a T for that with a clear line on top to show the water level in the tank and put the clear line in PVC pipe with a view window.
Mark Harley
Manual is good.
Gravity flow from the tank to fill pots
I wish I would have put my hose bib lower on the tub side.
matthewp
Combat Truck Monkey
So I will... I'm going to run a "manual" tap to the rear of the trailer, underneath the kitchen area. I figure it can do regular duty like Mark does with his.
Thanks for the input guys!
Xrunner
It might be worth considering adding a ball valve inside the trailer so you can disable the exterior tap too.
Robert Bills
I have used a spigot with gravity feed for many years and never felt the need for a pump (My Zodi Hot Tap shower has its own pump). The simplest solution is sometimes the best.
My 16 gal Ronco Plastics tank drains through a tube out the bottom of the tub through an existing hole in the frame to a spigot. I can fill the tank from the top, or by using the adapter shown, from the bottom by attaching a garden hose. There is an extra shut off valve under the trailer to prevent inadvertently losing water if someone forgets to close the spigot all the way.
Smudge12
