MOIRAI 1995 4x4 Fire Rescue BUILD Thread
Jdubucsd
Addicted to Espresso
Creighton Fabrication here in Ramona came up with this aluminum rack. To support a 4th 160 watt solar panel. Looks beautiful. Will be powder coating it black. Not sure if it makes the van look meaner or like something else..!? They also trimmed back the two front fenders to avoid tire rub
Jdubucsd
Along with the roof rack. I had all the rear seat brackets powdercoated too
Jdubucsd
Finally 640 watts of 12v panels. Mounted up and wired in. Front custom spoiler powder coated satin black and does the job. I could not hear any whistles or wind noises cruising around.
Jdubucsd
New EGT gauge. Turns out whoever installed the old one…had the wires backwards. So now there is an extra. Also new egt probe and lead wires.
New front door on door weatherstripping both driver and passenger sides.
Side entry step. All painted. Clean. Some Noico sound deadener and new stainless screws for the plastic step.
New front drivers and and passenger inner plastic fender liners. Creightnon fabrication pushed back the lower fender because the old liners had been pulled up by the 31” tires on the bottom. Now no rubbing. The rims can handle 33” safely. So if anyone had this down the road it can run 33” now. But the 31” KO2s on it now have only 1500miles or less.
Dry fitting the cold and hot water lines.
Jdubucsd
With Amazon and some creativity. I was able to access and Dicor all the roof mounts. Finally…
Jdubucsd
Plasti dipped the side door. Looks good. New front vinyl carpet. Thats the exhaust brake controller gizmo under the passenger seat.
Jdubucsd
It’s kinda cool you’ve got an exhaust brake. Do you find it useful? My Ambo didn’t come equipped with one.
Yes its cool. But I have not used it. It gets power. But the flange wont move. I havent made it a priority. I think it just needs to be broken free. And the switch by the gas pedal needs to be adjusted.
Jdubucsd
Well. Its back out in the wild. Storage served its purpose. Now its on the street. Was fun to give it a nice drive
Tracks perfectly straight
cruise control works
Just turned 110K miles on the way home
Seat brackets are getting powder coated
Rode home on milk crate
Jdubucsd
My dads 2005 Aliner behind his Nissan. Just bought it up near Seattle where he lives. Might be time to head up to PNW soon.
Jdubucsd
Working spot light. New vinyl flooring. Newly sealed dog house. Powder coated seat brackets. Disassembled and clean two front seats. Smells like new.
Bikersmurf
I really want to pull apart the cab and freshen it up like you’ve just done… but no time for it yet. Higher priorities, so it’ll have to wait.
Jdubucsd
whats your priority in your rig? For me the biggest thing is time and energy. I work quite a bit. So this build is taking forever….
Bikersmurf
My priority is my other rig. The 350 in My 40 series needs a valve adjustment to be drivable again. If that doesn’t resolve or improve the tap issue, perhaps a cam & lifters. If the intake is off, I have TPI to install. Also I need to swap the front 3rd and rebuild the front knuckles to be able to actually use 4wd… and so on.
The ambulance is fully operating and doesn’t really need anything. There are a couple minor things and a couple cosmetic things. Other than that it’s close enough to perfect. So it’s way down the priority list.
I also have no time, energy, or money to spend on it… other than the rear sway bar… that I’m picking away at.
Jdubucsd
Side storage door all complete. Powder coated cover. New screws. Sealed up etc. new keys and locks for the cylinders also.
for a side by side kinda comparison to the Revel. Obviously mine is smaller, height and floor space. But I have more solar and battery power and much less sticker price lol.
