MOIRAI 1995 4x4 Fire Rescue BUILD Thread
Jdubucsd
Addicted to Espresso
Jdubucsd
12volt mini split was condensating water. So I built a little drip tray to collect and drain it out. It would collect on the metal of the high and low pressure lines. Not much. But it was annoying.
Jdubucsd
Microwave and head board installed. Refoamed the board and enlarged the original HVAC outlet to allow for a small microwave. Reupholstered the head board also.
Jdubucsd
Covered up the unconnected amber lights with 3M adhesive and black aluminum 4x7 plates. Cleans up the rear a lot.
Jdubucsd
Added some sound deadening then 3M Thinsulate above the cockpit area. Nice change in noise and insulation thermally
Jdubucsd
Yes you can still get the spare off with out dismounting the mini split. But having AC is worth it. It has an outdoor BBQ grill covering it when not it use and it black. Helps it blend into the rear bumper when not in use.
Jdubucsd
Dome light. Works now! Also Trans temp gauge installed into the A Pillar
Jdubucsd
Built out the side steps for storage.
Yes glow in the dark grip tape!
Jdubucsd
Powdered coated the battery trays. Oddly enough the rear house batteries can start and run the rig. The two up front were out for a few weeks. Mmmmm…
Jdubucsd
IDM drain and cover. These Econolines have a terrible design. No more water running over the IDM or into the engine bay from the cowl.
Jdubucsd
Heater core replacement. Max AC bypass mod. And refoaming of the entire HVAC box. Makes a huge difference. Cleaned it all out.
