Montero 3rd gen radio install
jhill15
I just installed a new head unit so I thought I would do a write up on how to do it.
I purchased a jvc double din,
mainly because I like the look of a double din better as opposed to a single din but also because the previous owner had a double din and already switched the placement of the climate controls...sadly he put the stock infinity head unit back in before selling it to me.
None the less, if you would like to add a double din heres a video on how to get the center console out so you can lower the climate controls to where the tray is. On a side note If you have a dvd player then you probably dont need to watch it.
How to Remove DVD Player from 2004 Mitsubishi Mon…: http://youtu.be/-g75eQjmjXw
Here is the harness you will need to buy in order to install an after market radio.
Metra 70-7003
Metra 70-7003 Radio Wiring Harness for Mitsubishi Amp Integr https://www.amazon.com/dp/B0002ZGEO4/ref=cm_sw_r_awd_Mi2Qub14J4Z50
Heres how I did it.
First thing I did was wire the metra 70-7003 to the jvc harness. I did this the night before so it would be plug and play the next day. Usaually I would use crimp wire connectors to tie the 2 harnesses together but instead I just went old school with some electrical tape
Unhook the negative battery terminal
Unscrew the 2 screws above the compass/clock
Use a plastic panel tool to remove the surround, start on one of the bottom corners as it will come off easier
Unhook the hazard light harness from the surround and set the surround to the side
Remove the screws from the head unit and tray, set the radio and tray to the side
Attach your ground first so there are no issues with frying anything. I chose the left side of the dash bracket as the right side already has something grounded to it and I didnt want any problems
Plug the metra harness into the factory harness, make sure to align the amp integrated cable when plugging in
Plug the harness into the new head unit. Make sure that you plug the rca cables into the correct outputs on the back of the head unit
For the antenna, there are 2, so I just electrical taped off the small cable and plugged in the large one "sounds great even with a broken mast". Im not sure if taping it off matters but again I didnt want any problems after the install
Tuck the cables back in there and fit the new head unit. After this its probably a good time to hook your battery back up to make sure it works like it should
Put the surround back on and enjoy.
A couple problems I had on my specific truck that may help you if you encounter the same problems.
I had installed aftermarket led headlights prior to the new radio, when turning on the headlights while having the fm tuner on i got nothing but static from the stereo. I found out this was due to the driver/ballast of the leds. I pulled the leds and threw in some halogens and the radio was Crystal clear. For me I would much rather have a nice stereo as opposed to nice bright led headlights.
Another problem was with my factory sub. I noticed after putting in the new head unit its not working. Im not sure if it has never worked or is caused from the metra harness. Im still trying to figure that out.
Anywho, I hope this helps get some new stereos installed in your rigs!!!
montypower
Adventure Time!
Just noticed your climate controls are located way down low. My 03 has the climate controls under the radio. I wonder when they changed the location.
jhill15
mine were originally where yours are. The p.o. had moved em down so that he could install a double din. Pretty easy to do, theres a video at the top of the thread that shows how to get em down there.
Dr Gonzo
Interesting. Thanks for sharing!
I've been thinking of changing the headunit on my Gen 3 as well. Mostly just to get an Aux In plug and/or bluetooth audio streaming. From reading the comments on your amazon link for the harness adapter it seems you need to make sure your headunit has two preamp outs (Fr/Rr) so you can keep fader controls (like your unit does). I was not aware of that fact (and not all aftermarket units have this feature), so I learned something new today.
Also, I had no idea that both antennas each had a separate cable going to the headunit, I just assumed they would be joined by some sort of "Y" connector upstream of the unit. It seems the stock unit switches between the two (mast or rear quarter window) depending on signal strength. I listen to FM quite a bit and even stock with both antennas my Montero does not have perceptibly better reception than my other (newer) car with the stock single fixed rubber antenna (which is incidentally much shorter than the telescopic mast); so I'd guess not much would be lost by forgoing the glass mounted antenna. I wonder if anyone has had any experience with this?
Cheers!
jhill15
Thanks dr. Gonzo! The rca cables is something I didnt know about until I read the comments on amazon as well. So I had to go back and make sure that the jvc unit that I was ordering had 2 sets of pre amp outs.
Since I have a broken mast on my front antenna im considering pulling it and installing a fixed one. I havent made up my mind yet, mainly it would be for appearance as the jvc has much better reception as opposed to the factory stereo. Also it would be cheaper to installed a fixed antenna then buying a replacement power antenna mast.
Marutuk
KK6WFB
Thanks for the writeup, this should be very helpful as I was looking to replace my head unit in the coming days. :)
Marutuk
KK6WFB
I finally got around to this, so I got my new radio installed and it is nice to actually have a hands free setup for my car now :)
However, while it was pretty straight forward, I did run into the issue that there is a feedback from the car itself on the speakers, especially with the radio off (you hear the car revving up/etc), usually an indication that it's not grounded well. So I went over and double checked that as well as put some extra electrical tape on the connectors, but that did not help.
So I guess I have to check it out some more or may have to ask a professional for help.
jhill15
It definitely sounds like a bad ground especially if you here the engine revving through the speakers. Did you ground yours where I grounded mine?
Marutuk
KK6WFB
I did try it on two different spots with the same results (one on the metal frame where the head unit and such are mounted, the other a bit further back, similar to where you attached it). I may give it another try before seeing with a mechanic or car audio tech to check on it.
bikerjosh
Not to highjack the thread, but it there a way to split and if so which set of outputs to add a sub woofer. I recently replaced my factory infinity system with a an aftermarket deck with the required two sets of preamp outputs. I have a powered/subwoofer sitting on a shelf in the garage but it needs to plug into RCA jacks. Could you do this with "Y" shaped splitters from the back of the deck? Does this even make sense? :coffeedrink:
jhill15
You should be able to split the signal using one of these into the rear set of aux outputs coming from the aftermarket stereo
you would need to get 2 of the rca adapters, one for the left and right side of the rear output. With these you will be able to still plug in the factory sub...in theory it should work cause your not spiltting power just the signal. Heres the link to them. http://mobile.walmart.com/ip/RCA-3-Y-Adapter/16829790
vertical.dan
