(mostly) Low-cost 4x4 diesel high capacity chassis examples
2000 International 4800 4x4
$36,500
100,042 miles
Gross Weight: 33,000
Engine: DT466
Transmission: Allison Auto
• 2000 International 4800 4x4(Fully Reconditioned)
• Stock#683884
• Make: International
• Model: 4800
• Odometer Miles: 100,042
• Engine Hours: 4,071
• DT466 Diesel Motor
• 190 Horsepower @ 2300 RPMS
• 485Lbs Of Torque @ 1,500 RPMS
• Allison 3060P Automatic
• Marmon Herrington 4x4 Front Axle
• 5.83 Ratio
• Complete PTO System
• Front Axle Rating: 12,000lbs
• Rear Axle Rating: 21,000lbs
• Total GVWR: 33,000lbs
• 8’ 5” Cab Riding Height
• Steer Tires: 11R22.5- 75%
• Rear Tires: 11R22.5- 75%
• 152” Wheel Base
• Cab To Center Axle: 86”
• Rear Of Cab to Rear Of Frame: 135”
• Center Axle to Rear of Frame: 51 ½”
• Top Of Frame to Top of Cab: 62”
• Frame Height From Ground: 44”
• Frame Width Outside to Outside: 34 ½”
• Double Frame
• 50 gallon Diesel Tank
• Air Brakes
• Bench Seat
• AM/FM Radio
• A/C
• Cruise
• Push Button PTO
• Length: 23’ 5”
• Width: 8’
http://www.i80equipment.com/cgi-bin/inventory/inventory.pl?record=553
1996 PETERBILT 320 6x6
$23,000
? miles
1996 PETERBILT 320, 6x6 (10.5 yard mixer to be removed), super single rears, heavy frame, 21.5' of frame behind the cab, good running truck
1998 GMC C8500 4x4
$21,900
129,785 miles
1998 GMC C8500, [36220 GVW] 3116 CAT, 6.6L L6 Diesel, Allison Electronic 5 Speed Auto Transmission, Air Brakes, 11R22.5 Tire, FT Tread about 25%, R Tread about 60%, [snip], PTO, 184" Wheelbase, [snip] AM/FM Radio, Locking Differential, 4x4 With Low Range, Pintle Hitch WIth Air Trailer Hookup, 11 Compartments on Utility Bed, Spring Suspension, Exhaust Brake.
http://www.commercialtrucktrader.com/find/listing/GMC-C8500-102498794
Jlbeats
