(mostly) Low-cost 4x4 diesel high capacity chassis examples
And these listings will be forever known as mega-Lynn or Lynn-squared or Heavy-Lynn-Overlanding-Chassis-System (HLOCS) or ... :)
These are the 5-ton payload members of the the FMTV program that overlanders may be interested in:
  • M1083 5 ton Cargo Truck
  • M1084 5 ton Cargo Truck with MHE
  • M1085 5 ton Long-wheelbase Cargo Truck
  • M1086 5 ton Long-wheelbase Cargo Truck with MHE
  • M1087 5 ton Expansible Van
  • M1088 5 ton Tractor
  • M1089 5 ton Wrecker
  • M1090 5 ton Dump Truck
  • M1091 5 ton Fuel Truck
  • M1092 Truck, Chassis 5 ton
  • M1093 5 ton Cargo Truck LVAD LAPES/AD
  • M1094 5 ton Dump Truck LVAD LAPES/AD
  • M1095 5 ton Trailer (not included in this section)
  • M1096 5 ton Long-wheelbase Chassis
These variants are part of the Medium Tactical Vehicle (MTV) program with 5-ton / 10,000 lb / 4,545 kg capacity.
The Steel Soldiers forum also has resources for these trucks: http://www.steelsoldiers.com/fmtv/
There are some manuals for these trucks at www.armyproperty.com http://www.armyproperty.com/tm/9-2320-392-10-2
NSN 2320-01-354-3386
globalsecurity.org: http://www.globalsecurity.org/military/systems/ground/m1083.htm
olive-drab.com: http://olive-drab.com/idphoto/id_photos_m1083.php
Excerpt from olive-drab:
The M-1083 Family of Medium Tactical Vehicles (FMTV) 5 ton Medium Tactical Vehicle was produced in these variants:
M-1083 W/O WN (NSN 2320-01-354-3386)
M-1083 W/ WN (NSN 2320-01-360-1895)
M-1083A1 W/O WN (NSN 2320-01-447-3890)
M-1083A1 W/ WN (NSN 2320-01-447-3884)
The M-1083A1 variant, approved in 2000, features a more powerful diesel engine, a better transmission and brakes, added corrosion protection, computerized engine diagnostics, and beefier drive line engine/transmission/differential connection components. Other upgrades in the M-1083A1 include more durable seating material and cargo tarp, beefier door hinges, and reinforced sections that can be used as footholds to gain access to the cargo area.
Excerpt from Global Security:
The M1083 Standard Cargo Truck is designed to transport cargo and soldiers. The M1083 has a payload capacity of 10,000 pounds and to facilitate loading/unloading, the bed side rails are mounted on hinges. The cargo bed can be equipped with an optional bench seat kit for transport of soldiers. The bench seats are constructed of a non-wood material and attach to the cargo bed side rails. The seats can be folded down and stowed when not in use. Soldiers are assisted climbing in and out of the cargo bed area with the aid of a ladder stowed on the vehicle when not in use. A canvas and bows kit is provided to keep soldiers and cargo protected from the elements. The M1083 can be equipped with a self-recovery winch capable of fore/aft vehicle recovery operations. The winch has 280 feet of line capacity and 15,500 pounds bare drum line pull at 110% overload.
source: fas.org
source: olive-drab.com
source: globalsecurity.org
M1084 5 ton Cargo Truck with MHE (Material Handling Equipment - a crane at the rear of the cargo deck)
NSN 2320-01-354-3387
globalsecurity.org: http://www.globalsecurity.org/military/systems/ground/m1084.htm
olive-drab.com: http://olive-drab.com/idphoto/id_photos_m1084.php
NSN 2320-01-354-4530
globalsecurity.org: http://www.globalsecurity.org/military/systems/ground/m1085.htm
olive-drab.com: http://olive-drab.com/idphoto/id_photos_m1085.php
M1086 5 ton Long-wheelbase Cargo Truck with MHE (Material Handling Equipment - a crane at the rear of the cargo deck)
NSN 2320-01-354-4531
globalsecurity.org: http://www.globalsecurity.org/military/systems/ground/m1086.htm
olive-drab.com: http://olive-drab.com/idphoto/id_photos_m1086.php
Who knew? The Army has slide-outs! :)
I'd love to hear from a veteran who worked with these trucks if they were able to find a way to seal the slide-out to prevent dust/water/air intrusion into the box.
globalsecurity.org: http://www.globalsecurity.org/military/systems/ground/m1087.htm#
olive-drab.com: http://olive-drab.com/idphoto/id_photos_m1087.php
XM1087 Expandable Van
The XM1087 Expandable Van is envisioned to be a mobile office used at various echelons in a field environment. The M1087 van sides pull out from the main body to form the office complex. It is equipped with 110V AC to operate computer, radio and air conditioning systems. A 24 VDC electrical system is provided to operate the electrical components (radios and blackout lights, etc.) until the office complex can be set up. The vehicle is still in the developmental phase.
M1088 5 ton Tractor
NSN 2320-01-355-4332
globalsecurity.org: http://www.globalsecurity.org/military/systems/ground/m1088.htm#
olive-drab.com: http://olive-drab.com/idphoto/id_photos_m1088.php
M1089 5 ton Wrecker
NSN 2320-01-354-4528
globalsecurity.org: http://www.globalsecurity.org/military/systems/ground/m1089.htm#
olive-drab.com: http://olive-drab.com/idphoto/id_photos_m1089.php
NSN 2320-01-354-4529
globalsecurity.org: http://www.globalsecurity.org/military/systems/ground/m1090.htm#
olive-drab.com: http://olive-drab.com/idphoto/id_photos_m1090.php
NSN 2320-01-354-4527
globalsecurity.org: http://www.globalsecurity.org/military/systems/ground/m1091.htm#
olive-drab.com: http://olive-drab.com/idphoto/id_photos_m1091.php
globalsecurity.org: (no listing)
olive-drab.com: http://olive-drab.com/idphoto/id_photos_m1092.php
M1093 5 ton Cargo Truck LVAD LAPES/AD (air deployable variant)(this is the one to buy if you want to always be able to drop in on your buddies in the boonies)
NSN 2320-01-355-3063
globalsecurity.org: http://www.globalsecurity.org/military/systems/ground/m1093.htm#
olive-drab.com: http://olive-drab.com/idphoto/id_photos_m1093.php
M1094 5 ton Dump Truck LVAD LAPES/AD (air deployable variant)
NSN 2320-01-355-3062
globalsecurity.org: http://www.globalsecurity.org/military/systems/ground/m1094.htm#
olive-drab.com: http://olive-drab.com/idphoto/id_photos_m1094.php
Aren't you one of those 'stop planning and go' types?
Yes.
Go sooner with less rather than later with more.
You've been home too long now...
Yes. My wife feels that way about me once in a while too. :)
I do appreciate you sacrificing your productivity to uncover previously-unknown sources.
You are very welcome. I am very glad to help the community in some small way. Wish I had some practical experience with these trucks so I could add some in-use reality to what's here.
Jlbeats
