(mostly) Low-cost 4x4 diesel high capacity chassis examples
dhackney
1988 Kenworth 8x8
$37,750
Engine: Cummins NTC BC 3 Reman in 2007 3 Stage Jake Brakes
Transmission: 13 spd
PTO, Air Ride Susp,F - 20000lb, R- 46000lbs, Double Frame, Back of Cab to Trunion 21'6", Back of Cab to end of frame 27'6"
http://byrneequipmentsales.com/
dhackney
2001 International 4800 4x4 crew cab
$39,900
40,598 miles
Engine Specs International
Engine Type DT466
4X4 Crew cab/chassis w/ 108" cab to axle. Fabco four wheel drive running gear! 14' flatbed/utility body combo w/ over-head rack. Front mount 20,000lb Tulsa hydraulic winch! PTO powered Boss 8060-UBI air compressor. 185 cfm @ 100 psi. 110V power generator. Will remove body. Gross Vehicle Weight (lbs): 24800; 4x4
http://www.truckpaper.com/listingsdetail/detail.aspx?OHID=3582871&
dhackney
This is one is another prospect for a very cool restoration project.
Overlanding won't be a real market segment in the U.S. until there's a vintage category at the shows and races.
What do you mean? There's no U.S. expedition vehicle races yet? :)
One of these really belongs in a museum somewhere. A museum dedicated to how you survive in the Great White North. It would be a shame for these units, with all the parts, etc. to be broken up. (moment of silence)
But, if nobody up there is going to do that, they'd make a very interesting vintage platform for a period-correct camper box.
This is a potential package deal. They've got two of these and it looks like you may need to combine the two of them to get one running. At a minimum, you'd probably want the second unit for spares.
1950 MARMON SB125R
http://www.truckpaper.com/listingsdetail/detail.aspx?OHID=3257409&dlr=1&pcid=2001003232
Marmon-Herrington ( Ford truck with Snow-Go mounted snowblower, All wheel Drive, with Front mounted snow blower , Seperate engine . Unit was Used its life on small Airport. Was used in service until two years ago. All parts are there and unit also has chains for the tires. Older unit but still blows snow. We have 2 of these units. Blower is run off a continetal engine .
http://www.truckpaper.com/listingsdetail/detail.aspx?OHID=3257455&dlr=1&pcid=2001003232
Ford truck converted to Maron-herrington ALL Wheel Drive with Snow- go Snowblowers., Hydraulic lift, pto driven front mounted snowblower, Unit was used until 2 years ago at Small Airport, Been stored inside , unit ran when parked and will still blow snow. Unit is priced AS-IS. Unit is available by Appointment only to inspect. Can be loaded on truck and hauled away. We have two , so we will make a package deal. Can still get parts for snow blower-- Will entertain offers AS-IS. Great units to move snow .
Most of the photos are from the first listing.
dhackney
1982 AM GENERAL 6x6
$29,900
? miles
1982 AM GENERAL OTHER, NHC250 Cummins Engine 240 hp 16,917 mi Diesel Fuel Type Automatic Camelback Suspension 10R20 Tires All Steel Wheels Tandem Axle 4,500 gal Capacity Steel Composition Water system was built around 2000 it is in great shape the tank is very clean It has 2 front sprayers 2 rear sprayers and 1 side sprayer Water pump is rebuilt with a new hydraulic drive pump 6x6
http://www.commercialtrucktrader.com/find/listing/1982-AM-GENERAL-OTHER-99578765
dhackney
1989 Chevrolet C70 4x4
$9,500
45,563 miles
Engine Make: Detroit
Engine Model: 8.2 turbo diesel
Transmission Make: Allison
Power Steering
1989 Chevrolet C70,4X4 chevy - very good over all condition1100X22.5 90% on bud wheels- air brakes 30,000gvwtransfer case pto- hi/lo and 4X4 all air shift- double frame rails 11' -230 turbo dieselNice heavy duty 4X4 truck with front mounted 20,000 lb winch 45,000 original miles!!!10,000lb rockwell front drive axle20,000lb Eaton rear drive axle
http://www.commercialtrucktrader.com/find/listing/1989-Chevrolet-C70-103608309
Clemtiger84
