Mr_Miyagisan
Great looking build so far!
Jelly. How are the 33s on stock gears? Is it doable? Ive probably missed those duratracs most from that jeep.
Sent from my HTC One_M8 using Tapatalk
I have 32's on 3.73's and while not optimal, not terrible. Power is okay except above 4500 feet, mpg is around 14-15 combined surface/freeway.
Your staying with 4.56 gears right?Finally getting around to re-gearing the rear Chrysler 8.25. While I'm at it, I'll be adding an ARB rear air locker, new bearings, seals, etc. Rear axle will be brand new!
Those motor mount are good idea, had a friend break off his engine bracket, caused all kinds of problems!
Decided to go with 4.88s since I am heavily weighed down when I go on long trips. I also dont daily drive this vehicle so gas mileage wasnt a concern
That should be comparable to an auto trans with 4.88s from what I've heard. I have the auto trans and also don't plan on going larger than 33s. Everyone I have met that went larger had to upgrade to beefier steering components and axles since it was much harder on them. Sounds like you have a sweet setup 😁I have axles w/4.56 and ARB lockers I plan on putting into my XJ. Mine has a 5 spd. I have 33" KO-2's no plans for larger tires and will be pulling a home made trailer, I am hoping it is steep enough to make taking the mountain passes a little easier on the rig. I don't daily drive mine either. Right now it has 3.55 gears and the 33"s it lacks the ump right now. Hoping to take it to Moab in the fall.
