Mounting the Hi-Lift is the million dollar question or as my gf always says 'don't worry, you'll find something else to worry about soon enough'
I over-analyze everything. If the hi-lift weighed 10lbs I'd definitely mount it to the roof rack, it looks cool and perfect there away from the lower parts of the truck which may be burried in the sand etc when you need the jack. But being a 35lbs of heavy hunk of metal I don't feel comfortable mounting it to the roof rack. In the event of a crash or a rollover it could do a lot of damage and for that same reason I don't want it inside the truck either. So the best place would be a swing out carrier on a custom bumper. However, since I don't have one of those the best place I've come up with is the rear hitch with a custom mount so it's at bumper height and in the crash crumple zone. I see GoWesty.com has one and it's cheap enough to not build my own but I don't like how the tongue of the jack faces downward which makes the departure angle worse- I've scraped the rear hitch a few times climbing out of gulleys etc. So it'll probably be a custom mount on the hitch.
Hi-Lift is one of the most useful tools to have if you learn to use it right. It can be used for winching though it's slow and painful when used that way but it's better than having nothing when you need one. On a stock truck you can use the hi-lift in two ways, one is with the Lift Mate attachment which lifts at the wheel. This is a preferred way of lifting in most offroad situations so you're not lifting on the body where the suspension travel can take a while to fully extend before the wheel actually lifts...in some cases you run out of the length of even the hi-lift jack. The second place is the rear hitch reciever.
The rock sliders have been a consideration and most likely the next mod
Oh, the BendPak lift...thanks, it's been one of the best 'investments' for the garage. I have/had lightweight racing jacks, heavy duty long reach jacks, several jack stands etc that I keep hanging on to but honestly I haven't used most of them ever since I bought the lift in 2008. One push of a button and the car is up and secured in 10secs flat. No jacking up from multiple places, no placing of jack stands all over the place, no blessing the car before getting under it, no wondering if the car will get knocked off the jack stands while you're trying to undo the darned rusted bolts under there. For me it's been 100% worth the price If I had the room I'd get the two post lift which is even better...though requires a bit more care.
