HenryJ
Set the top on, mark around the feet and cut the floor away. Fairly easily done with a grinder and cut-off disks. Leave a little room and you can weld the frame together and run a bead to attach the floor too.Welded the floor on. I am not too sure that I should have done it this way though. I removed the box (it was only tacked in a few spots) and welded the floor down. Then I'll weld the box to it. I only question myself here for the fact that the box is welded to the floor and not the frame. would this concern any of you pro's?
You are better to weld the frame together. I would avoid sandwiching the floor between.
I have been known for overkill too. Others may disagree.
Looking good. Although I may not always speak up. I am watching and enjoying the build.
