My Jeep JKU dual battery tray install.
dstock
Not to Hijack, but the NL Split Charge manual shows both factory pos and neg connected to the main battery.
http://www.nationalluna.com/Datasheets/Split-charge%20manual.pdf
jungblud
I separated the negative cable run that courses through the base of the fuse box and is grounded to the fender and routed it behind the batteries to the same spot. Tidied it all up with some loom and silicon tape.
While I was at it I rearranged the approach to the hold down. I ordered some stainless all thread for the engine side. Rerouted the oba and spod accessory wires as well. Need to shorten one or two.
Overall much better routing and protection for the wiring than I had before. Not to mention wiring the NL proper this time.
dstock
Nicely done! How did you attach the hold down to the tray on engine side? I want to make something similar since I am in the process of pulling my batteries and recovery charging them, now is the time!
jungblud
I'll weld an overhang on the engine side next week for the hold down. Waiting on stainless all thread now and I'll drill holes and call it done.
