New 270 Awning available.
Time to add couple of more to the list!!
**************************************** 270deg awnings **********************************************
Reign Outdoor 270 FR-
self supporting awning, three attached oles are included. $950, close dim = 94.5" long, 95" wide, 9.5" height. 83sq ft coverage, 40 lbs, https://reignoutdoor.com/store-2/p/style-01-ej5na-kj67d flip up rain peak, velcro strip for optional walls
Taruca Bushwakka Extreme Darkness 270 - three attached poles, $1500, closed dim=91" long, 145sq ft, 62lbs, https://tarucausa.com/taruca-extreme-270-lhs-awning/. Optional wall available.
Taruca Bushwakka Extreme 270 - one attached pole, $1300, closed dim=98" long, 129sq ft, 58lbs, https://tarucausa.com/taruca-extreme-darkness-270/. Optional wall available.
Freespirit Recreation 270 - No poles needed, $1100, closed dim=96", sq ft?, 37lbs :oops: (lightest awning), https://gofsr.com/products/freespirit-recreation-270-awning
iKamper Exoshell 270 - fresstaning but poles included, $1750, closed dim=103", 66lbs, 121sqft, ripstop nylon (may not UV reflective up top, my guess). @shoredreamer has pics on his 80 post #289
BF Campers (Canada) Freestanding up to 25 km/hr, $1,200 CAD$, sq ft? closed dim? https://www.bfcampers.com/product-page/270-degree-awning. (may not UV reflective up top, my guess)
ARC 270 by Roam Adventure company, 56lbs, need poles, 92sq ft, closed dim 90", $1400, ripstop sailcloth, (may not UV reflective up top, my guess) https://www.roamadventureco.com/products/270-awning?variant=43970998108392
Campking- Freestanding, Closed dimension 2.3m (91"), 24kg (53lbs), area? Coming from Aust. (maybe UV reflective up top, my guess) Sold by Rhino gear $2500 , https://campkingus.com/products/cam...reestanding-270-awning?variant=42577918492835
Roofnest Litewing
- 30 or 40 lbs depending on regular or XL model. Coverage is 70 or 100 sqft. The alum case is 7" wide x 8" tall x 100" long. https://roofnest.com/product/litewing-awning/ cost is either $1195 or $1295 (XL). Rafters are made of carbon fiber.
Darche Eclipse GEN2
48lbs https://overlandaddict.com/products/darche-eclipse-270-awning-gen-2, 87" length, 124 sqft,$1,299
Doghouse 270 - 40lbs, https://www.doghousetents.com/products/free-standing-270-degree-awnings?variant=37027629858981, 92" length, area sq ft?, $985 CAN
Wraptor 6k -
70lbs ( bracket weight is 5lbs x 3) https://overlandpros.com/product/wraptor-6k-270-degree-freestanding-vehicle-mounted-awning/, 88", sq ft?, $849
Wraptor 4K -
61lbs (includes bracket weight 5lbs x 2) https://overlandpros.com/product/wraptor-2500/, 86" length, ?? SQ FT, $800
Alucab Shadow -
24kg/51lbs https://www.alu-cab.com/product/270-shadow-awning/, 102" length, 100 sqft, $1,500
Rhino Rack Batwing -
47lbs (40# minus brackets) http://www.rhinorack.com/en-us/products/sport-leisure/shade/awnings/batwing-awning-left-_33100, 98" length,115sqft, $800
Rhino Rack Batwing compact -
40lbs https://www.rhinorack.com/en-us/pro...de/awnings/batwing-compact-awning-left-_33300, 79" length, 69sqft, $688
OVS Nomadic -
72lbs https://overlandvehiclesystems.com/...lack-cover-universal/#product-tab-information, 88", 129 sqft, $900
OVS LT (lighter model)
53lbs, https://overlandvehiclesystems.com/...7-dark-gray-cover-with-black-cover-universal/, 83" long, 80 sqft, $699
OVS Nomadic 270LTE -
31 lbs, four attached poles but not required. 75sq ft coverage, dimensions = 71"x6"x6" https://overlandvehiclesystems.com/...de-270-degree-awning/#product-tab-description
Peregrine 23Zero -
51lbs https://23zero.com/product/peregrine-270-us-drivers/ 88" length, ? sqft, $1,000
Kingsmen 270,
70lbs, https://www.kinsmenhardware.com/products/awning, 91" length, 85 sqft, $2,150+4mos lead time
James Baroud 270,
weight? https://adventure-ready.com/store/james-baroud-falcon-270-awning/, ? length, ? sqft, $1500 (driver side only)
Bush company 270XT,
61lbs (53# minus brackets), https://www.southernxpeditions.com/bush-company, 90" length, 86 sqft, $1450, no poles are required or provided.
Bush Company 270 MAX,
73lbs (new to the market) https://cascadiatents.com/bush 270xt max awning left.html, 90" length, 130 sqft, $1750
Ostrich Wing
57lbs, https://www.ruggedbound.com/products/ostrich-wing-awning , 104" length, 120 sqft, $1480, no pole design,
Howling Moon 6 panel awning 2.5m-
38kg/83lbs with reflective material - https://www.howlingmoon.com.au/product/6-arm-270-degree-swing-awn, 98" length, ? sqft, $1795 AUSD
Howling Moon Swing awning 2.5m,
55lbs, https://www.howlingmoon.com.au/product/270-degree-awning, 98" length, ? sqft, $1390 AUSD,
Quick pitch weathershade 270,
60lb, https://tgmoverland.com/collections...k-pitch-weathershade-20-sec-awning-270-degree, 101" length, 161 sqft, $1380
EEziAwn Bat
46lbs, https://www.equipt1.com/products/bat-270-awning, 95" length, 80sqft, $1300
EEziAwn Manta
50lbs, https://www.equipt1.com/collections/270-degree-awnings/products/manta-270-awning, 100sqft, $1400
**************************************** 360deg awnings **********************************************
RLD DESIGN GhostAwn
360 Awning - 48lbs (weighed by Shoredreamer) https://www.rhinoadventuregear.com/products/rld-design-ghostawn-360-awning, 96" length, $1,400
Bundutec Bunduawn 360 DEG 44lbs, https://bundutecusa.com/bunduawn/ - no pole design 96" length - $1,515, 108" length - $1590, and 116" length
this is an aside but someone who is more familiar with HTML code may know this answer. See how Camp King industries url is producing the pic in my post? How do I get rid of the pic but keep the URL so that others can click on it? Do I have to modify the URL somehow?
edit: using a diff URL for campking
I just installed the Freespirit 270 on my GoFast camper. Although the awning seems solid-enough, I have been a little disappointed with the quality. It has a very "amazon off-brand" feel with regard to the construction and hardware. For example, the kickstand, used to elevate the tarp in rain, feels pretty cheap and seems to have been mounted incorrectly. It will not deploy in its current position because the pivot is located too close to where the tarp material attaches to the frame. This can be corrected by drilling a new hole for the mounting point, which isn't a big deal, but maybe not something that I should need to do for a new product. Only time will tell how well it holds up to real world use. My initial opinion is that if you are looking for something that is bomber, you would be better served to look elsewhere.
In order to mount the FSR 270, I purchased three separate awning mounting brackets directly from GoFast Campers. I do not believe that the mounting brackets provided with the awning will work for the GoFast's. It is also worth noting that the awning does not come with the support pole that is shown in the video on the website. I knew this going in, but it isn't entirely clear from their website. The FSR 270 does ship with guylines and beefy ground stakes to tie down the corners in wind.
Overall, I think the FSR 270 is a good purchase at the current sale price of $875, but probably not at the list price of $1250.
With that in mind, I'm pretty bummed about how Freespirit handled the preorder pricing for the awning. Folks that preordered paid up-front at 10%-off MSRP. However, the kicker is that the day the preorders were shipping, FSR sent out the email advertising 30%-off "Black Friday" pricing on the awning - in October! I did inquire via email whether they might extend that sale price to the preorders, but was totally ghosted. I probably wouldn't feel so bad about paying the higher price if the quality was better. That's business, I guess. Lesson learned.
Thanks for the feedback. Based on your post and taking another look at the amount of coverage I decided against the FSR.
I went to the OVS office to check out their awning and was discouraged by how hard it is to stow away after using it. The velcro straps are too short and the cover was very tight.
Now leaning towards the Overland Pros Wraptor 6K and hoping to check one out in person soon,
You're smart to check these things out in person. The tightness of the bag is an important thing to consider, you have a rare luxury that most of us don't!!!
Don't think I saw this one on the list. Looks like now they're offering a free awning wall as well.
Taruca
Extreme 270 @ $1299. 58LBS, 129 sq/ft, 98" long
Extreme dark 270+ version @ $1499. 62lbs, 145sq/ft, 91" long
I like these but it says that their canvas is not waterproof. Not sure how well it will hold up in the rain.
  • Our Awnings are designed primarily for sun shade and not for heavy rain events. While our Awnings are made with water-resistant materials, they are not waterproof. It is important to note that during heavy rain or extreme weather conditions, we recommend taking necessary precautions to protect your Awning and gear. Please use caution and always follow recommended guidelines for setup and usage of our Awnings in order to ensure the best possible experience.
Bummer. I will say, my OVS 270 kept us dry during some Wyoming rains while camping this summer.
The Taruca Awnings are currently 30% off the 2023 models or 10% off a 2024 model. Was basically free shipping for the 2024 270° Extreme Darkness one I just got.
A question..... Which of these awnings actually open up to a true 270 degree. I was looking at the OVS but it is more like a 260. This leaves a big gap at the point of where my OVRLND ends at the end of our F250. Since I have the barn doors, it would not keep any rain off the tail gate area..... Thanks Jeff
tbnd88
