New 270 Awning available.
dcg141
I’m surprised no one makes a rear 180 awning that is around 72” wide when stored.
I’m also surprised no one makes a rear and side awning that connect creating a 270.
One of the coolest set ups I ever saw was from Howling Moon. They had a 270 awning that integrated into a tent creating an absolute massive living space. See below.
Howling Moon needs to find a better US distributor.
concretejungle
I found this in my recent search. Didn't see it discussed here (at least if so I missed it).
Anyone have experience with this one?
iowalr4
I just installed a 23 Zero 270 on my LR4. The rear bar that should be parallel with the back of the vehicle isn't quite parallel, and it does hit my ladder a little. Raises the bar up about an inch. I have it mounted as high up as I can with the brackets that came with it. My tailgate opens all the way it just rubs a little. I may have to just protect the metal that rubs for now.
I don't see how the other options would work at all though. The support bar that goes straight back doesn't touch the tailgate.
I do agree that more coverage in the rear would be ideal, but with the tailgate the way it is, its tricky. It gives fantastic shade and space on the driver side though. Very impressed with the side coverage. That is most likely the area I need most as it is where the chairs and table and such would go. Hard rain may still be an issue with the tailgate area, but I was thinking I could get the rear walls and just attach half of it on the skimpy section to make it rain proof.
I'll get some photos up of it soon.
iowalr4
I have to crank the arm on the back up a bit to make the ladder clear, but it does. I don't have to push too hard on the arm. Kinda worries me anyway. It seems really strong but it has some flex to it. I moved the whole thing forward a little to make it better, but I don't want to go too far. Without the ladder it would fit just fine, but I do use it to get up on the roof. Especially when I need to use my roof boxes.
pilgrim81
Finally bought howling moon 270 swing awning ... it's a bit heavier but so much nicer than my old chinese 270 awning ... :love:
5hiq3jqyw9ExwOduV2J58Qz7EZLCHj4rbAsDL0Nml28j039MohwpQ2MeVjKIcFtpTgytlmrg6qKN0YV1EDudhm6O5zwU1uO5BiCy66Jy2Qn5IxdBJmIPGtaiVPHyMw1cVjlSwby9CYc=w2400
eu2lnFwVkPB4gjk5mODVV7y36MENYrCfcgk4y-NsxtEf23KmQm_k5xiDvaoXBrcWFmJ5xfLqj2ILehWaP044UqDWtHrg6KJDFZYJ5094Sd1z8JskykQ8A6nxN5h40VlE912LAEEUJxY=w2400
build quality is superb
GfhBYjArBkbVCWSIKzcru5l3uD4g2hUPlEdriZuLfLTZX5fjWt1XbpMbabccEFNt04RqS-8-OiIVUeYUHjIMCpDPS8yAja_DvM8c92czYJawCp9xMJZ8L1Seu-7-5MniA7jWx-qTL9k=w2400
alia176
Awesome pics, @pilgrim81. Which one specifically did you purchase? Please let us know the cost and vendor info. I'll update my running list.
Thx.
alia176
I'll bring this info down here and update with latest info. Has anyone purchased a HM awning from USA? If so, let me have the vendor info.
Thx.
Alucab Shadow awning - 24kg/51lbs https://www.alu-cab.com/product/270-shadow-awning/ $1,500
Rhino Rack Batwing - 47lbs http://www.rhinorack.com/en-us/products/sport-leisure/shade/awnings/batwing-awning-left-_33100 $800
OVS Nomadic - 72lbs https://overlandvehiclesystems.com/...lack-cover-universal/#product-tab-information $1,000
Peregrine 23Zero - 51lbs https://23zero.com/product/peregrine-270-us-drivers/ $1,000
Darche Eclipse - 48lbs https://backwoodsoverland.com/product/darche-eclipse-270-awning-drivers-side-generation-2/, $1,150
RLD DESIGN GhostAwn 360 Awning - 68lbs https://www.rhinoadventuregear.com/products/rld-design-ghostawn-360-awning, $1,400
Howling Moon 360 6 panel awning 2.5m- 38kg/83lbs with reflective material - https://www.howlingmoon.com.au/product/6-arm-270-degree-swing-awn, $1795 AUSD
Kingsmen 270, 70# https://expeditionportal.com/forum/threads/270-deg-square-back.190248/post-2549081, $1500+4mos lead time
James Baroud 270, weight? https://adventure-ready.com/store/james-baroud-falcon-270-awning/, $1500 (driver side only)
CharlieGreenT
