greg.potter
Most of the electrical system is in place and is performing as expected. The system is broken down into 3 installation areas that I call the "Component Panel", the "Sub Panel", and the "Control Panel".
The Component Panel is located behind the fridge and can be accessed through a hatch on the passenger side wall of the camper. For any major service needs the fridge can be removed (it's on wheels) and the hinged Component Panel can be swung open for easy access.
The Sub Panel is also mounted on a hinge so that both sides can be accessed through the hatch.
The Control Panel is located above the fridge and has all of the control switches, systems monitoring displays, as well as the AV system.
Very nice work on the panels - based on the quality of the design & workmanship I'm guessing you are control system engineer or panel builder.?
