New member, 2001 montero limited.
off-roader
is not 2001-2002?
On my 96SR, I was able to use a fan and clutch from a sport with the 3.5l engine.
You can probably cross reference it by checking the part numbers for different year monteros and Montero sports using vin numbers from each year/model (see faq post on 4x4wire) and the Mitsubishi ASA program (download from Mitsubishilinks.com).
RichardT
I haven't had any problem yet with cooling, but there's a lot of good info here, so I'll be following this closely
:lurk::coffee:
grandpa
Bad Gauge
This could be a gauge issue. I have this problem with my 2001 Montero. The gauge slowly moves up and down but mainly stays on hot. I have verified that the engine temp is normal. There is a circuit board on the back of the gauge panel that can cause the temp gauge to read hot when the engine temp is normal. The dealer says to replace and reprogram the circuit board is $800-$900. Do a web search for bad Montero temperature gauge. There are a lot of reports of this over the years. I am planning to add a secondary digital temp gauge.
Yep, funny, those little bugs. A friend just bought a 2006 Honda Civic Hybrid. Check engine light comes on so she takes it to autozone to get it checked out, codes point to catalytic converter. She then goes to an exhaust shop where they ordered her a new catalytic converter ($350?!?! + labor!?). I decided I'd run the codes with my OBDII scanner. The car only has 70k on it which red-flagged me about it not being the cat. So I ran the codes on the net, and sure enough the 2006 Honda Civic Hybrid has a recall where they need to reprogram the computer to reflect the correct catalytic temps in the sensors. Check engine light goes off, and hasn't come back on. She's now stuck with a $350 catalytic converter that she doesn't need (shop wouldn't return or refund a special order item)... but at least I saved her the labor costs, another $300...
My point is that unless Grandpa said something, its quite frustrating how much money one could spend trying to figure out an issue!! Thank goodness for Uncle Google.
armostunt
Oh and I just noticed the top hose on the radiator is clapsing (inflated or getting flat looking) when the motor was hot after I turned the car off. Is that anything to do with that. Should I change it ?
armostunt
So I checked and I checked test after test and now the gauge works fine and the motor was never running hot. The upper hose now won't Calaps like it did when I saw it. I hope that never happens again. I went to Azuza Canyon today just to check to see if the 4x4 hi lo works and it does.
On a side note can you guys tell me when I should put the 4llc and 4hi. And what's the difference ? Thanks Eric.
off-roader
Do you have the owners manual? Explains the difference there. You can get them pretty cheap on eBay if you don't have one.
In a nutshell 4LLc is 4wd Low range with the transfer case center dif locked. You use it when you need the extra gearing and want both front and rear tires spinning especially when your in a tough spot.
armostunt
But doesn't the 4hi turn the front and back? I had a jeep xj and it had 4hi 4low and full time 4.
I had a yj to and it just had a 4hi 4low. But I just don't understand the locking center diff. ?
scrubber3
Not really here
Without the locking center diff, if one tire started spinning, you wouldn't move at all. Like an open front or rear diff but with 4 wheels. Without the center diff, it's basically an AWD.
