My expensive (48 bucks) grill has been used, broke, fixed and used again!
Couple thoughts:
1) It is compact, does not weigh much and simple, all a plus for me.
2) The gauge of metal is a good compromise, I do not think it will last forever but it is not too heavy either.
3) It has two screws and two nuts that allow the grill to hinge. One of the screws fell out and was lost. I never checked them out of the box to make sure they were still tight from the long cruise over from China but no matter it was easily fixed.
4) The ashes must be removed before the grill will fold. I lined the grill with foil and after the ashes had cooled rolled it all up and threw it into the trash, no trouble.
5) No heat control. There are no vents and the grill height is set. I increased the heat by covering the meat with foil and it worked fine for a couple of bison steaks.
6) Doubles as a fire pan when a summer monsoon dumps copious amounts of water on your camp all of a sudden, good times!
So far I am happy with the grill, it works fine for my uses.
