Odyssey vs. Diehard Platinum
Herbie
Rendezvous Conspirator
Great info dwh, that pretty much confirms my expectations (and concerns). It seems if one is using such AGMs and needs them to be fully charged you either need (a)periodic access to mains power and a proper charger, (b) some sort of high-voltage alternator and the rest of your auto-electronics suited to match, or (c) some sort of voltage-boosting DC-DC charger.
Not sure if (c) exists on the scale we're talking about here. In the embedded electronics world where I function, we have many projects where we charge a 14v NiCd off of a 12v supply using a variety of "charge pump" or other circuits, but these are decidedly low amperage applications...
dwh
Tail-End Charlie
Not just AGMs - any lead-acid battery.
In terms of charging, the main difference between AGMs and regular flooded lead-acid is that the AGMs can handle a lot more charge/discharge current (amps) without damage. The charge voltages are pretty much the same either way. Gels have slightly different (lower) charging voltage specs, but AGMs and FLAs are pretty much the same.
Any old alternator will put out sufficient voltage (if the rpms are high enough), but you need a special voltage regulator/charger unit if you want to hold the voltage up for a length of time (absorb stage). Like these:
http://sterling-power-usa.com/proregd12volt24voltadvancedalternatorregulator.aspx
http://sterling-power-usa.com/alternatortobatterychargers.aspx
Oh sure, there are plenty of DC-DC converters for charging lead-acid batteries. Here's a couple:
http://www.powerstream.com/DCC.htm
http://sterling-power-usa.com/sterlingpowerusabatterytobatterycharger.aspx
Spur
My Platinum PM-1 has 1150 CCA. I think it should be fine as a starting battery. :coffeedrink:
I wish I would have known about the extra CCA requirements for using a deep cycle as a starting battery before I purchased my platinum 1150. I'm on my third one in less than 18 months. The stock battery for my 92 cummins engine was 1100 CCAs. Single battery, not duals like a lot of modern diesels. When I bought the truck it had an optima yellow top that failed right around the time I did the engine swap so I went with the die hard platinum marine. It was the only battery they had with that high of CCAs. The latest failure was fairly catastrophic. It leaked and now there is significant corrosion on my battery tray. So much for them not leaking.
I'm not sure what I'm going to do now. I like the idea of getting two die hard platinums and hooking them up in parallel, but space is tight and that would be about $450!!!! Compare that to an 1100 cca battery from O'Reilly for $130.
rambrush
When I went to Odssey's website this is the info they have for the 92 cummins. I am partial to Odssey and my twin 1200's are doing great.
Year1992
MakeDodge
ModelW350
Engine5.9 Liters 359 CID L6
BCI Group Size30H
ODYSSEY MODEL25-PC1400T
Pulse (5-second) Hot Cranking Amps (PHCA)1400
Cold Cranking Amps (CCA)740
20Hr Nominal Capacity (Ah)60
Reserve Capacity Minutes100.00
Dimensions
L x W X H - Inches
9.46 x 6.58 x 8.69
Metric Dimensions
L x W X H - mm
240.3 x 167.1 x 220.7
Weight (lbs)50.00Weight (kg)22.70
Spur
Year1992
MakeDodge
ModelW350
BCI Group Size30H
Dimensions
L x W X H - Inches
9.46 x 6.58 x 8.69
Metric Dimensions
L x W X H - mm
Thanks for the info. I looked at the website myself and I'm a little confused. That would be undersized. I guess they assume two batteries in parallel but they make no mention of it.
SChandler
On the 89-93 Cummins/Dodge trucks, the factory battery configuration was a single Group 31 with an 1150CCA rating. The information that Odyssey has listed for the 89-93's is actually the battery rating for 94 and up Cummins/Dodge trucks. When Dodge changed body styles they went to a dual parallel battery set up on the Cummins trucks.
I have two 1st Gen Dodges: a 90 and a 92. Both have a single Group 31 battery. They both run a Les Schwab branded replacement that has "only" 950 CCA and neither one has a hard time starting, even down to about 15*F.
toy_tek
A little followup performance info:
06-2008 - Original Group 34 Diehard Platinum purchased
10-2011 - Replaced for free
04-2012 - The replacement battery then suffered an early death after just 6 months(!?) Again, replaced for free with just 2 months left on the original 48 month free replacement term.
tgwagen
that's good news for sure!
Ok, just got back from Sears. They had plenty in stock. Guy behind the counter said they're getting more popular.
(2) Platinums for $389.00 out the door.
48 Months Full Replacement Warranty - 52 Months Prorated Warranty - 100 Months Total Warranty
I'll install them tomorrow and post pics.
can't wait to see the pics..
ckkone
I followed this thread back in the day and my starting battery finally died so I upgraded to a DHP Group 34. I guess the timing was right because Sears.com had them on sale for in-store pickup. I paid $164.95 and used the code SEARS2012 for an additional $5 off, with tax it was about $170. I managed to get it installed with stuff I had laying around the garage from past projects.
HenryJ
Nice! I'll play...I see your Diehard platinum:
...and raise you one:
Two under my hood! :)
Platinum and Odyssey likely one in the same
Just wrapped up some lengthy research and discussions with Enersys on the PC 1750 vs Sears Diehard Group 65 P-2 for my '99 Powerstroke. Found this forum and thought many might be interested in the comparison and special charging needs for deep cycle service. Have also included a PDF table for the comparison. While Enersys would not state the batteries were the same, they did say the batteries were made on the same production line. The table tells me a lot.
View attachment odyssey 1750 vs diehard P2.pdf
You will probably find similar comparisons between other Sears Platinum and Odyssey models and group sizes.
This posting has undergone a few edits and some visitors coming back to the site have probably noticed that. Most of that has been for clarification and to direct readers to the Odyssey publications.
If you are considering this type of battery, especially for deep-cycle service, be sure to go to the Odyssey web site to learn about this technology's charging needs. If you never deeply discharge this battery, charging requirements are likely to be more forgiving. If you allow the battery to become depleted without taking into consideration parasitic loads, that counts as deeply discharging just as it would if you were running accessories before recharging. Also consult the General Provisions section of the Warranty in the owner's manual which also specifies information on charging needs.
There is an owner's manual AND a technical manual for these batteries available for download. Generally speaking, for deep-cycle operation you will need a charger that can provide ~40% of the 10 hour rating for the bulk charging stage PLUS nominal 14.7 and 13.6 constant voltage absorption/float stages. So, for a battery with a 10 hour rating of 65 amp/hours, you will need a charger capable of supplying a nominal 25 amps in the bulk stage plus the nominal voltages for the absorption and float stages.
The material goes deep into charging procedures for 3 different designs of automatic chargers as well as guidelines for manual chargers. I had covered some detail when first posting this, but have removed it because I felt the expeditionportal viewers would be better served by consulting official Odyssey pubs. Go to the Odyssey website http://www.odysseybattery.com/ for the most current information. If you use a manual charger, be sure to understand the transition points and limitiations between stages.
I would venture to say that if your battery is forced into float before charging current is reduced as described for the timed absorption stage, your battery is likely beginning to lose capacity. Desulfation might correct the issue. Do not allow the charging voltage to ever exceed 15 volts. This will cause the internal pressure valves to open and out-gas hydrogen. Voltages of 15 volts and higher can easily be reached by the older unregulated chargers as the battery approaches full charge.
If you cycle these batteries as one might typically would for flooded lead acid deep-cycle batteries while boon-docking or on a sailboat [discharging them to 50%, then recharging to 80% (typical for maximum generator efficiency)], these batteries will likely be killed off in less than a year. If you recharge them with just any off the shelf so-called "smart charger", you could very likely get only 75% of the design life from them. Do not trust chargers that claim to have an AGM setting without verifying the profile needed for the Odyssey batteries!! Nearly every charger I have examined, even those that claim to have an AGM mode, either provides absorption and float float voltages that are too low to obtain maximum life from the Odyssey battery or the charge profile is not even specified!!
Be sure the nominal constant voltages mentioned above are measured at the battery, especially if the charger has detachable cables. On a very expensive charger/inverter setup I own, I was using jumper cables from the charger output. Voltage at the battery was .3 volts below the required voltage level, while the temperature compensated voltage at the charger output was correct. Switching to the proper gauge cable eliminated the voltage drop and provided the exact same voltage at the battery as the charger terminals.
Be sure the voltage output of the charger is temperature compensated. One chart I use (from Xantrex) shows charging voltages for absorption and float for AGM batteries should be decreased .1 volts from nominal for every 10° F increase in temperature above 70° to avoid the pressure valves from opening. Voltages should be increased by the same amount for every 10° F decrease in temperature below 70° to avoid undercharging the battery. While this chart is useful and you might be able to rig up a manual charging process, you will be better served with an automatic temperature compensated charger specifically designed for this battery technology.
Also, the stock converter/charger found in most RVs is woefully inadequate for any kind of battery long term, let alone for something of the caliber of an Odyssey/AGM battery. They will cook a flooded battery and undercharge an AGM, which shortens the life of the AGM. These converters are still used today because they are cheap, not because they are good for your battery!
Odyssey does provide a list of recommended chargers if you're not going to use an Odyssey Charger and it looks like it is updated each year. Do not use trickle chargers to charge a deeply discharged battery. Trickle chargers and float chargers are intended ONLY for batteries that are already nearly fully charged.
My "odyssey" with the Sears Diehard Platinum is just beginning. After learning of the challenges associated with AGMs in general, I took a voltmeter with me to make sure that only the 2 batteries with the highest open circuit voltages were chosen. Of the 10 that were there, 8 measured in the 12.6-12.7 volt range. I found 1 with 12.86 volts and another with 12.93 volts. An open circuit voltage of 12.84 or over is considered 100% charged. The voltages of the other 8 indicated states of charge (SOC) between 85%-95%. All were manufactured within one month of each other and the 2 I chose presumably had a lower self discharge rate since leaving the factory.
Have not yet bought a charger as am able to make do with the combination of chargers I already own, but Sears says the Diehard Platinum 71227 charger can be returned if it's charging profile does not match the profile described in the Odyssey Technical Manual, especially the 40% of 10 hour amp hour rating. The failure rate of the 71227 is reported to be somewhat high, but within the 3 year warranty period. If it were to fail, replacing it could be easier locally, but also note that after 2012 Sears may be dated as a retail concern. I will likely end up with the Odyssey Ultimizer OMAX-25-1B and is warranted for 5 years.
Practically all major battery manufacturers are starting to jump into the AGM market. There are leaders and followers of this technology in the industry. Specifications and prices can vary greatly. If an AGM for your group size weighs only 45 lbs with one mfr and 60 lbs with another, there is a reason for it. Mostly, it's to get the cost down. Performance will be affected proportionally. You cannot assume they are all the same. I would avoid any brand of AGM where the manufacturer cannot provide detailed written information on how to take care of them. I would also avoid chargers that where the charging profiles for each setting are either not specified or don't meet your intended AGM's manufacturer's requirements. I respect an AGM's retailer to need to make a living, but all of them I talked to don't have a clue about what these batteries need. Consult the manufacturer for any brand you are considering.
Hope this helps somebody.
teotwaki
Excelsior!
If you'd like to charge the second battery well while driving consider the CTEK 56-677 Dual with temp compensation and an input for solar panels that uses MPPT techniques. Unfortunately the cheapest place on the web just jumped the price from $155 to $191. Otherwise buy a very good AC powered charger that provides the proper charging. You can get a non U.L. rated Samlex really really cheap here:
http://www.hamradio.com/detail.cfm?pid=H0-006241
ldivinag
i'll tell you this...
my plat DH doesnt like sitting a vehicle for about year without being used/charged/maintained...
lol...
went to a autozone platinum that is an AGM design also...
