VanIsle_Greg
haha! Moving van does Whipsaw!! Check out the site again cause more pictures have been posted.
Will do. Haven't been on there in a few days...need my fix.
Howdy....your rig is beautiful. I am putting a camper on my fg and was wondering if you still had "extra" dometic windows?
Wow... This rig is AMAZING. Incredible work! Thank you for documenting it and sharing it all. So awesome..Keep it up!
Speaking of...
Are you finished with the interior then, have you finally settled on how the entire thing will be inside, or are you considering another change with it?
Regards,
I'm a bit late catching up with your progress Westyss but having done the Whipsaw on a few occasions I have to say I'm Very (with capital V) impressed you ventured out there and made it so "gracefully"! I would have loved to join you guys to see this beast in action! Seems like you dialed your suspension quite right, amazing flex for such a large truck...
Must have been a pretty tight fit at times, and I bet it was priceless to see the face of unaware drivers seeing you on that trail!!!
Well done, keep enjoying!!!
Cheers,
Mr. D
Hello what a great build thanks for posting.
A question. It appears from the pictures that the camper has only three smallish windows mounted high. Do you wish you had better views and are the windows low enough to see out when seated?
Amazing work Westyss! I've got a question for you about your frame mounts. Any chance I could get a little more in depth write up on how your mounting system works. Also How has it held up? any distorsion and damage after the offroading? I've researched a lot and it seems most folks are looking into the pivot frame design but i like you method it looks much more simple. Have you had any problems with the Forward/Back preventer or the side load preventer? I assume that there is a side load preventer on both sides? Thanks and kudos to you for the detail and extent of your craftmenship.
After looking closer I guess one of my main questions is in the front to back preventer picture why does it seem that the space/gap appears to be 1-2 inches and in other photos the gap looks more like 4 inches as you stated?
