Petersons Ultimate Adventure Tundra
01tundra
Received my wireless thermometer from Wil yesterday, only took a few minutes to install and works great. The display reads the ambient temp in the truck, the fridge temp, & also has a clock. It only took about 20 minutes on the #2 setting to bring the fridge down to 32F :cool:! I mounted the remote display panel on my cage with a Fourtreks cage clamp & velcro and mounted the temp sensor on the lid of the fridge with the supplied velcro.
01tundra
Here's the rest of the "latest" mods.....since joining this forum :drool:! I have posted some of this in other random threads, but attempting to pull it all together into my build thread so everything's in one place.
Lightforce Striker 170 lights -
Outdoor thermometer -
National Luna Dual Battery set up -
Water can & mount -
01tundra
First use a good hole cutter bit like these -
http://www.vansantent.com/sheet_metal_cutters.htm
Then dimple dies with a pneumatic shop press (or impact wrench & thru bolt, or a hydraulic jack and steel table, or....anything that will compress the two dimple die halves) -
http://www.vansantent.com/sheet_metal_machines/punch_flare_tools.htm
Here's a picture of my bed during fabrication - we were able to use lighter (10 Ga) steel and make it strong by using dimple dies. That's really the reason behind using them, to keep things strong and light.
And a few other things like antiwrap bar -
Bump stop gussets -
Rear axle truss -
Rock sliders & backing plates for the boat sides -
Front bumper plate -
Spring perches -
Tube doors -
Cage gussets -
Ok damnit.....so I have a "thing" for dimple die holes :)!
01tundra
We just got back from a 4-day camping/wheeling trip in Harlan, KY for the April Fools Toyota run - had a blast! Camping on the mountain got a little interesting on Thursday night when a pretty rough storm blew through. Oh yeah, this was the first trip with the Engel also....all I can say is wow, we are definitely spoiled now :wings:!
Here we are playing in the little rock garden deal.....
And letting the girl drive for the 1st time :D!
01tundra
I almost got to try out the roll cage this weekend at Grayrock, but the only picture anybody got was on a cell phone after I had finally got it to climb out of this monster rut. At one point, I could lean my elbow out the window and touch the ground......
As usual, the picture is very deceiving - if you tried to run the "flat" looking area above the rut, you would be almost guaranteed a roll because it's way off camber. This is the "Big Egg" trail, did it the evening prior when it was dry like it wasn't even there......the mud made things a little more interesting.....
Also just found out that we're going to give the Ultimate Adventure another shot this year.....if these R&P's do a repeat, I'm retiring from this crap!
dyogim
Yeah right! If that happens, we'll probably see a set of portals or rockwells underneath. :smiley_drive:
Rusty-Ford
John
Love what you have done with the tundra.. i drool when i see it.
That was a major jones busting the r&p's but you kept on going and the truck kept doing its thing anyways!
Great job and keep it up. Some of us are living vicariously through you here!
I love the UA's as well.. someday i want to get there but i have alot of work to do before then. Can you spill where it will be this year or is that a no no?
01tundra
Man I wish I knew where....or even when we were going - we don't get that info until about a month prior, not knowing is the tough part! It's definitely a little unnerving!
Rusty-Ford
that's cool.. i am sure it will be fun no matter what.. just maybe a little more interesting if it is on the west coast or somewhere with a LONG drive.. i wish they would come northeast sometime!?
Clemtiger84
