Ok, so im listening to you guys. Im keeping the bike and riding it for now. If i fall in love, and i know i will... i'll get something else later. But for now.. im sticking with it and making it new again. Here's my list from working on it a bit tonight..
Air Filter
Front Fender Plastic
Side Fender Plastic
Headlight and # Plate
New Grips
New Handlebars (these look bent slightly)
Rear Tire
Front Tire (depends how bad this one is, looks fine/not cracked)
New Fuel Lines from Carb/tank area (one leaks, mine as well do them all)
Tonight i cleaned the bike more and tried to find the fuel leak from under the tranny.
It's one of the 3 clear hoses and i don't know which so i'll just replace all.
Also i checked the electrical with my meter. Good to go, the stator is putting out 12
volts. All lines for the headlight, rear lights and a 3rd (im thinking
for the odometer?) are showing power. So that's good. Also i noticed tonight the
mechanical cable coming from the hub for the tripometer... thats' good, its still there and
in great shape, just duct taped to the fork up high. I also adjusted the rear brake tonight.
Seems 10x better than before. May need to re-do both front and rear brakes.
Should i get a new chain?
So all in all im in for a couple hundred.... not too bad. And i found a OEM tripometer on Ebay so hopefully i can find another when it comes time. Wish i had money right now, i'd be ordering all these parts tonight!
