Post up your drawer/storage system
motoboss
Bad Influence
Ok collective, first off let me say thank you for the great information and inspiration in this thread. I'm a complete n00b when it comes to any advanced woodworking. I do have the tools and knowledge in general construction but no experience in cabinet construction, other than making a box.
I'm working on plans for my Jeep XJ drawer, frig storage unit. Question is, where do I find a double pull out slide for my stove/prep tray combination? I have seen several units with a pull-out flat surface then a pull out under that holding a stove. That's my ideal set up, but for the life of me can't find any information on where to purchase or how to install. Google has not been my friend.
I'm also looking for the slides to hold my Yeti 45 cooler on a slide out.
The system in this video is the unit I am wanting to copy. Any help on sources?
https://youtu.be/iXWjDUnotJQ
TemboTusk
Rendezvous Con
You might want to check out Goose Gear and AT Overland. They both have a different concept of what you might be looking for.
motoboss
Bad Influence
Thank you
Is the double platform called, a "combo slide"? I don't want to have the stove and frig on the same slide, just a cutting board/prep top and the stove. The AT is way overkill.
Edit;
Ahh I think I see now! Is the double slide just 2 drawers put together, one inside the other? So a box drawer open on the front with a flat prep top on top, and another flat bottom with the stove sitting on it mounted on slides inside the prep top box!
Or am I seeing something else and not getting it?
Outsane
Home built drawer/sleeping platform set up super simple
Sent from my SAMSUNG-SM-G891A using Tapatalk
tbisaacs
200 series DIY build
I just completed a drawer build for my 200-series. I have zero wood working experience and this thread was super helpful. I originally had planned on doing a setup with hinged wings but decided against it to simplify the design to my skill level.
Carcass and drawers are 1/2" birch, top is 3/4". Note the HPDE "slides:
Outer height is about 10" to keep my fridge low but also give me the option to sleep on it:
The finish is matte gray, hand-hammer texture. The handles are from an outdoor gate kit. I trimmed the top with an aluminum threshold and an indoor / outdoor mat that I glued down with 3M super 77:
SportsmanJake
Has anyone built (or is there documentation somewhere) a truck bed drawer that is weatherproof (exposed to elements) and made out of wood/mdo?
I want to build one similar to TruckVault but would love to get some ideas before I dive in.
So far, I am thinking the following:
* LxWxH: 6x4x1
* 3/8 or 1/2 MDO for outside shell
* 72 inch Accuride sliders for the 2 drawers.
* carpeted drawers
* Bedlined exterior.
Thanks.
MCX
TalesFromTheDesert.com
The Titan rear drawers seem like a great value - Titan Rear Drawers. They have different sizes, too. Unfortunately, I contacted the company (4WD Supacentre) and they don't ship to the US and I can't seem to locate a different distributor. The price and features are great, so I'd be very interested in getting a set for my Xterra.
Charp
* LxWxH: 6x4x1
* carpeted drawers
Thanks.
Yeah, built mine with 3/4" plywood and covered it with Deck Restore 10x by Rustoleum. Cheaper and easier than bedliner, but looks the same. I didn't use the Restore thick roller, just a medium sized paint roller. Covered the top with flex seal, but will be removing that because I like the 10x better.
SportsmanJake
Nice. Have you had any issues with water intrusion?
SouthTXplorer
I bought a similar drawer set up, I think some distributors in the US have them as "van cargo drawer", probably not as robust as those Titans, but I have had no problems throwing my yeti cooler fully loaded on top, and heavy oilfield parts.
  • Like
Reactions: MCX
Dmski
Here is mine! I was tired of digging for gear and having my boxes slide around in the back of the truck. This worked out really well. Built myself a rear storage setup.
I ended up building the whole thing out of 5/8" plywood and used some free southco latches from work, and 100lb drawer slides from rockwell hardware and bolted it to the floor using 3/8" unistrut inset mounts. All in it cost me $80ish dollars and works well. I still need to build a sleeping setup as well build the small side storage compartments using some free hinge material and leftover wood.
KZxbNlMDnv7ESXfu6x-wl13Lmnf_xCmE69TF6MrvN1zKLFqfkS9poQhBwaPYSRj01_EIlBqWVpiGBf9JFJIImE77TPZ_syZBA1rt13T4J5wkgNi4uSlwoOyFMDNLMcUXH4K1UqoohQ
1vVwE0zgxoUMK2nQv0h1XzT5jEnQMgUeZEkai2btjJdyVoVcRIfcHNNC_ZRm8XX5P-TWNnEAW2XJVvLBsiMvo_xIzJysNlbyWHgva-stjNvDtTMqJc1pq2V3CFXjn19exzYol5OKgg
m36RQ8QtqnXChNvCtK65K9hl0eJjJ89iZAvabTODNjoRk42xK_-7xvY0vWPP7dxqAgXEX1gWo_a0JtOkYkuxErmsKgaGvUGX-dT5I-7-zjUE6nyX6I_xJf22DMZ9SkK7lvtKA3I9eQ
rZ2DX9eV37D76rAT6mtXcLIKwOJTtP-4SFjv181CAT3qWKhyGysZRm9dal6638KG0YPD2wZVTRZPRYCB5tqtmhO_JBzUGmS4fVJavidWBRfvb0gEmuRt_QGGAo__PtSyrHP9OBqE-Q
CEQxJNN1bEqRswA8CZgUr2Br3rID63J85IKok1fhezfPyX-_ABuWx5TLtEdWy4LYbj_jkdgnTJZ9VbrvnFlLMzn3hrjsNfJoJEjO_QritScturGtYq3qYGL5EUexxJ635x1Jtoh6Jg
xzpfzdtUsp5C7XqH1p960_8tbqJ5PhE3U5--ol6220th_ySHRbcK_6C4NbhMpyzVCMStVts9XMjyB2NT5q2B3GZ3yyTpii6jELFfqcyOuRezo-9Hi2dSp_4PA2vuua6Ygm9_jigAlA
vertical.dan
